1406-4
    KEYSTONE
    CONN PC PIN CIRC 0.024DIA GOLD
1406-4 数据手册
R TI F I ED MICRO PINS 2 T Y CE 900 ISO Q I UAL .017 Pin - SWAGE MOUNT • Precision engineered and manufactured • Space saving design for high density packaging • Micro pins are available in .017 to .080 diameters • Ideal for mating with our standard line of micro jacks • Available for press-fit, swage or solder mounting • Sizes for .032, .062, .093 and .125 thick PC boards • Custom micro pins manufactured to your specifications • Other platings available upon request SPECIFICATIONS Material: Brass, ASTM-B16 Plating: Gold: .000010 per MIL-G-45204, Type II Tin: .000200 to .000300 per MIL-T-10727, Type 1 .018 Pin - PRESS-FIT GOLD TIN PLATED PLATED CAT. NO. CAT. NO. 1988-2 1989-2 .018 Pin - PRESS-FIT Mounting Hole .026 Dia. .020 Pin - SOLDER MOUNT GOLD PLATED CAT. NO. 1998-3 1999-3 TIN PLATED “A” CAT. NO. Dim. 2000-3 .250 2001-3 .425 Mounting Hole .024 Dia. .025 Pin - SWAGE MOUNT GOLD PLATED CAT. NO. 1407-1 1407-2 1407-3 1407-4 TIN PLATED “L” Bd CAT. NO. Lgth. Thk. 1427-1 .051 .032 1427-2 .082 .062 1427-3 .113 .093 1427-4 .145 .125 Mounting Hole .052 Dia. .040 Pin - PRESS-FIT GOLD TIN PLATED PLATED CAT. NO. CAT. NO. 1990-2 1991-2 MATERIAL Phos. Bronze Mounting Hole .026 Dia. .025 Pin - SWAGE MOUNT GOLD PLATED CAT. NO. 1404-1 1404-2 1404-3 1404-4 TIN PLATED “L” Bd CAT. NO. Lgth. Thk. 1424-1 .051 .032 1424-2 .082 .062 1424-3 .113 .093 1424-4 .145 .125 Mounting Hole .052 Dia. .025 Pin - SWAGE MOUNT GOLD TIN PLATED PLATED “L” Bd CAT. NO. CAT. NO. Lgth. Thk. 1401-1 1421-1 .065 .032 Mounting Hole .043 Dia. .040 Pin - SWAGE MOUNT KAY PIN TUBULAR HOLLOW PIN Stake to .062 board. Mounting hole .059 dia. MATERIAL: Solid Nickel Silver CAT. NO. 1219 TIN PLATED CAT. NO. 1968-1 1968-2 1968-3 1968-4 “L” Lgth. .051 .082 .113 .145 Bd Thk. .032 .062 .093 .125 Mounting Hole .052 Dia. GOLD TIN PLATED PLATED CAT. NO. CAT. NO. 1986-1 1987-1 .018 Pin - PRESS-FIT Press-fit into .043 dia. hole CAT. NO. 1218 82 GOLD PLATED CAT. NO. 1967-1 1967-2 1967-3 1967-4 .018 Pin - PRESS-FIT MATERIAL: Brass, Tin Plate GOLD PLATED CAT. NO. 1992-2 1993-2 TIN PLATED “A” CAT. NO. Dim. 1994-2 .243 1995-2 .140 .020 Pin - PRESS-FIT Mounting Hole .022 Dia. .025 Pin - SWAGE MOUNT GOLD PLATED CAT. NO. 1408-1 1408-2 1408-3 1408-4 TIN PLATED “L” Bd CAT. NO. Lgth. Thk. 1428-1 .062 .032 1428-2 .094 .062 1428-3 .125 .093 1428-4 .156 .125 Mounting Hole .062 Dia. .040 Pin - SWAGE MOUNT GOLD PLATED CAT. NO. 1405-1 1405-2 1405-3 TIN PLATED “L” Bd CAT. NO. Lgth. Thk. 1425-1 .051 .032 1425-2 .082 .062 1425-3 .113 .093 Mounting Hole .043 Dia. .080 Pin - SWAGE MOUNT GOLD TIN PLATED PLATED “A” “B” CAT. NO. CAT. NO. Dim. Dim. 1447-1 1455-1 .335 .156 1447-2 1455-2 .400 .125 1447-3 1455-3 .400 .125 1447-4 1455-4 .400 .125 Mounting Hole .026 Dia. “L” Bd Lgth. Thk. .051 .032 .094 .062 Mounting .125 .093 Hole .156 .125 .094 Dia. GOLD TIN PLATED PLATED CAT. NO. CAT. NO. 1996-2 1997-2 Mounting Hole .040 Dia. .025 Pin - SWAGE MOUNT GOLD PLATED CAT. NO. 1406-1 1406-2 1406-3 1406-4 TIN PLATED “L” CAT. NO. Lgth. 1426-1 .047 1426-2 .078 1426-3 .110 1426-4 .141 Bd Thk. .032 .062 .093 .125 Mounting Hole .035 Dia. .040 Pin - SWAGE MOUNT GOLD TIN PLATED PLATED “L” Bd CAT. NO. CAT. NO. Lgth. Thk. 1402-3 1422-3 .125 .093 Mounting Hole .062 Dia. .040 Pins - INSULATED SHORTING PLUG RED CAT. NO. 1460R 1461R 1462R 1463R BLACK CAT. NO. 1460B 1461B 1462B 1463B “A” Dim. .200 .250 .400 .500 “L” Dim. .375 .375 .620 .620 INSULATOR: Plastic, Red or Black PINS: Brass, Gold Plate 31-07 20th Road • Astoria, New York 11105-2017 • (718) 956-8900 • FAX (718) 956-9040 e-mail: kec@keyelco.com • WebSite: keyelco.com
1406-4 价格&库存
很抱歉,暂时无法提供与“1406-4”相匹配的价格&库存,您可以联系我们找货
