T0054490699
T0054490699
    ATG
    THMCSOLDERINGTIP3.2X0.8MM(1
T0054490699 数据手册
PROFESSIONAL Product Information WT1 and WT1H Soldering Stations with the new high performance WTP90 soldering pencil Conserve valuable workspace with our new, user-friendly, stackable soldering units. These next generation, single-channel soldering stations aim to please. The detailed LCD screen enables an unprecedented overview of all functions, quick and easy to reach via the new user-friendly menu button. If you need even more performance than 90 W, then the smart solution is the higher-powered WT1H, with available power up to 150 W. Features and Benefits Front panel power switch New menu button operates multi-functional LCD screen New, high-performance WTP90 soldering pencil 2-in-1 WSR safety rest Stackable units Technical Data Dimensions LxWxH Fuse 120 V (A) Weight Power supply Power consumption ESD safe Temperature range WT1 WT1H 150 x 130 x 101 mm 5.91 x 5.12 x 3.98 in T1 T1.6 2.7 kg 5.95 lbs 3.8 kg 8.37 lbs 120 V / 60 Hz 95 W 150 W Yes WT1H Soldering Station 150W WTP90 Pencil, 90W Order no. WT1N Order no. WT1HN Order no. T0052922299 50 °C – 450 °C / 550 °C 150 °F – 850 °F / 950 °F (550 °C / 950 °F – WP200 only) Temperature accuracy WT1 Soldering Station 90W ± 9 °C / ± 17 °F WTP90 complimented by new high-mass THM tips! PROFESSIONAL Product Information WT Stations, sets, pencils and tips The unique, reversable WSR safety rest flips between sponge and brass wool. WT1010 Set pictured. Order no. Part description Order no. Part description Safety Rests WT Sets WT1010N WT1010: WT1 / WTP90 / XNT A / WSR200 120V NA T0051517499 WSR200 SAFETY REST FOR WTP90 WT1011N WT1011: WT1 / WP65 / XNT A / WSR201 120V NA T0051517599 WSR201 SAFETY REST FOR WSP80 / WP65 / WP80 / WP120 WT1012N WT1012: WT1 / WSP80 / LT B / WSR201 120V NA T0051517699 WSR202 SAFETY REST FOR WSP150 / WP200 WT1013N WT1013: WT1 / WP80 / LT B / WSR201 120V NA WT1010HN WT1010H: WT1H / WP120 / XT B / WSR201 120V NA Accessories WT1011HN WT1011H: WT1H / WP200 / XHT D / WSR202 120V NA T0058768727 WSRF200 FUNNEL REPLACEMENT FOR WSR200 / WDH51 T0052922399 WTP90 PENCIL, WSR200 SAFETY REST T0058768728 WSRF201 FUNNEL REPLACEMENT FOR WSR201 T0058768729 WSRF202 FUNNEL REPLACEMENT FOR WSR202 / WDH31 New THM SolderingTips T0058768726 TIP CHANGE TOOL FOR WTP90 T0054490499 THM A 1.6 X 0.4MM (1 PC.) T0058768724 BARREL / TIP RETAINER FOR WTP90 T0054490599 THM B 2.4 X 0.8MM (1 PC.) T0058768725 REPLACEMENT HEATING ELEMENT FOR WTP90 T0054490699 THM C 3.2 X 0.8MM (1 PC.) T0058768731 WSRH2 XNT TIP MOUNTING / STORAGE PLATE T0054490799 THM D 4.0 X 0.8MM (1 PC.) T0058768732 WSRH1 LT TIP MOUNTING / STORAGE PLATE T0058768733 WSRH3 XHT TIP MOUNTING / STORAGE PLATE T0058768734 SILICON PAD REPLACEMENT FOR WT1 / WT1H weller-toolsus.com © 2017 Apex Tool Group, LLC | 1000 Lufkin Road, Apex, NC 27539-8160 USA | Phone 866.498.0484 | weller-na@weller-tools.com | ATG-2888 PDF only. Specifications subject to change without notice.
T0054490699 价格&库存
很抱歉,暂时无法提供与“T0054490699”相匹配的价格&库存,您可以联系我们找货
