WT1012N
WT1012N
    ATG
    WT1012:WT1/WSP80/LTB/WSR201120
WT1012N 数据手册
PROFESSIONAL Product Information WT1012 1-Channel Soldering Station digital 95 W Product no.: WT1012N Benefits Digital Soldering Station WT 1, 120V, 60Hz (95W) with WSP80 and WSR201 WSP 80 soldering iron for all standard soldering applications. Tip family: LT Front Panel Power Switch OFF time, Prozess window, Lock function, Offset PROFESSIONAL Product Information Technical Data Dimensions L x W x H (mm) Dimensions L x W x H (inches) Weight (approx.) in kg 149 x 138 x 101 5.87 x 5.43 x 3.98 1.9 Voltage 120 V Power 95 W Channels 1 Temperature range (depends on tool) °C Temperature range (depends on tool) °F Temperature accuracy °C 50 - 450 150 - 850 ±9 Temperature accuracy °F ±17 Temperature stability °C ±2 Temperature stability °F ±4 Equipotential bonding socket Display Via 3,5 mm pawl socket on front of device Backlit LCD Air consumption l/min --- Operating pressure in bar/psi --- Capacity l/min --- Vacuum --- Weller Tools GmbH Carl-Benz-Straße 2 74354 Besigheim Germany Phone: +49 (0) 7143 / 580-0 Fax.: +49 (0) 7143 / 580-108 Email: info@weller-tools.com Web: www.weller-tools.com
WT1012N 价格&库存
很抱歉,暂时无法提供与“WT1012N”相匹配的价格&库存,您可以联系我们找货
