Micro Metal Geared motor w/Encoder - 6V 310RPM 50:1
SKU:FIT0482
INTRODUCTION
A new micro metal gear motor with a difference! This motor comes with a built-in encoder which measures the motor's speed in
real time. The average output number of pulses can reach up to 7*2*50 pulses per revolution. The motor has a long (0.354"/9.0
mm) D profile metal output shaft that is compatible with the 42x19mm and 32x7mm dimensions of the Pololu wheel. The brass
faceplate has two mounting holes threaded for M1.6 screws (1.6mm diameter, 0.35mm thread pitch), or you can use the mounting
bracket or extended mounting bracket which are specifically designed to securely mount the gear motor while enclosing the
exposed gears. We recommend the extended mounting bracket for wheels with recessed hubs, such as the 42×19mm wheel.
The hall sensor of new version has 7 pole pairs, so the encoder resolution will be increased by 7-fold.
Compatible with 2WD miniQ Robot Chassis.
SPECIFICATION
Rated Voltage: 6.0 V
Motor Speed: 15000 RPM
Gear Reduction Ratio: 50:1
Reducer Length: 9.0 mm
No-Load Speed: 310 rpm@6v
No-Load Current: 60 mA
Rated Torque: 0.35 kg.cm
Rated Speed: 180 rpm@6V
Current Rating: 170 mA
Instant Torque: 0.8 kg.cm
Hall Feedback Resolution: 700
Weight: 18g
DOCUMENTS
Motor Interface https://github.com/Arduinolibrary/DFRobot_Micro_Metal_Gearmotor_with_Encoder/raw/master/Interface.png
Motor Dimension https://github.com/Arduinolibrary/DFRobot_Micro_Metal_Gearmotor_with_Encoder/raw/master/Dimension.jpg
SHIPPING LIST
Micro Metal Gearmotor 50:1 w/Encoder x1
6-pin connection cable x1
2-pin 1.5 mm JST connector x1
4-pin 1.5 mm JST connector x1
Powered By DFRobot © 2008-2017 https://www.dfrobot.com/product-1432.html 4-27-17
很抱歉,暂时无法提供与“FIT0482”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+159.87178
- 3+151.08762
- 国内价格 香港价格
- 11+134.8457411+16.29087
