Additional Resources:
Product Page
date
08/05/2022
page 1 of 3
MODEL: PJ-043 | DESCRIPTION: DC POWER JACK
ED
FEATURES
N
U
• 1.65 mm center pin
• 2.5 A rating
• vertical orientation
• through hole with panel slots
SPECIFICATIONS
conditions/description
rated input voltage
rated input current
contact resistance
insulation resistance
at 500 Vdc
voltage withstand
at 50/60Hz for 1 minute
terminal strength
life
Vdc
2.5
A
50
30
mΩ
mΩ
500
Vac
0.3
3
kg
500
g
-25
85
5,000
°C
cycles
UL94V-0
O
Note:
units
MΩ
any direction for 10 seconds
operating temperature
max
16
100
N
insertion/withdrawal force
RoHS
typ
between terminal and mating plug
between terminal in a closed circuit
1
flammability rating
min
TI
parameter
yes
1. When measured at a current of less than 100 mA/1 kHz
IS
C
SOLDERABILITY
min
typ
max
units
wave soldering
dipped in solder pot for 5 ±0.5 seconds
255
260
265
°C
D
parameter
cuidevices.com
Product Page
CUI DEVICES | MODEL: PJ-043 | DESCRIPTION: DC POWER JACK
date 08/05/2022 | page 2 of 3
MECHANICAL DRAWING
units: mm[inches]
tolerance:
X.X ±0.2mm
X.XX ±0.1mm
X.XXX ±0.05mm
PLATING
copper
nickel
ED
center pin
MATERIAL
brass
tin
terminal 2
copper alloy
tin
terminal 3
brass
tin
plastic
PBT
D
IS
C
O
N
TI
N
U
terminal 1
Note:
Recommended PCB Layout
Top View
SCHEMATIC
MATING PLUG
Jack Insertion Depth: 9.50 mm
Model
PJ-043
Center Pin
Ø1.65 mm
1. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted.
cuidevices.com
Product Page
date 08/05/2022 | page 3 of 3
REVISION HISTORY
description
date
07/30/2007
1.0
initial release
1.01
applied new spec template
1.02
brand update
1.03
modified housing mold
1.04
logo, datasheet style update
ED
rev.
01/14/2015
10/28/2019
04/20/2021
08/05/2022
D
IS
C
O
N
TI
N
U
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“PJ-043”相匹配的价格&库存,您可以联系我们找货
