Additional Resources:
Product Page
3D Model
PCB Footprint
date
09/04/2020
page
1 of 4
MODEL: PJ-006B-SMT-TR │ DESCRIPTION: DC POWER JACK
FEATURES
2.5mm center pin
4 A rating
vertical orientation
surface mount (SMT)
RoHS
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
rated input current
contact resistance1
between terminal and mating plug
between terminal in a closed circuit
insulation resistance
at 500 Vdc
voltage withstand
at 50/60Hz for 1 minute
any direction for 10 seconds
-25
life
A
mΩ
mΩ
500
Vac
3
kg
500
g
85
°C
5,000
flammability rating
UL94V-0
RoHS
yes
Notes:
4
50
30
MΩ
0.3
operating temperature
units
Vdc
100
insertion/withdrawal force
terminal strength
max
18
cycles
1. When measured at a current of less than 1 A.
SOLDERABILITY
parameter
reflow soldering
see reflow profile
min
cuidevices.com
typ
max
units
260
265
°C
Product Page
3D Model
PCB Footprint
CUI Devices │ MODEL: PJ-006B-SMT-TR │ DESCRIPTION: DC POWER JACK
date 09/04/2020 │ page 2 of 4
MECHANICAL DRAWING
units: mm[inches]
tolerance:
X.X ±0.3mm
X.XX ±0.2mm
9.00 0.35
PLATING
copper alloy
nickel plated
terminal 1
copper alloy
silver plated
terminal 2
copper alloy
silver plated
terminal 3
copper alloy
silver plated
plastic (housing)
LCP
plastic (bottom cover)
PA10T
13.20 0.52
2.50 0.10
6.30 0.25
MATERIAL
center pin
R2.25 0.09
10.90 0.43
10.60 0.42
6.25 0.25
0.80 0.03
14.27 0.56
14.10 0.56
4.50 0.18
4.20 0.17
5.00X4.50
2.00 0.08
(2 PLCS)
3.85 0.15
1.25 0.05
1
3.10 0.12
1
9.00 0.35
4.50 0.18
2
3
4.55 0.18
6.25 0.25
2.25 0.09
4.50X4.90
(2 PLCS)
2.50 0.10
(2 PLCS)
1.25 0.05
4.75 0.19
4.80 0.19
3
2
2.65 0.10
5.0 0.20
PCB LAYOUT
TOP VIEW
1
3
2
SCHEMATIC
MATING PLUG
Jack Insertion Depth: 8.95mm
cuidevices.com
Model
PJ-006B-SMT
Center Pin
Ø2.5 mm
Product Page
3D Model
PACKAGING
units: mm
Reel Size: Ø380
Reel QTY: 250 pcs per reel
cuidevices.com
PCB Footprint
date 09/04/2020 │ page 3 of 4
Product Page
3D Model
PCB Footprint
date 09/04/2020 │ page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
12/12/2005
1.01
added missing dimensions
10/18/2007
1.02
housing material changed
02/09/2011
1.03
added TR package option
11/07/2012
1.04
applied new spec template, updated rating
08/30/2013
1.05
brand update
10/31/2019
1.06
added tape and reel packaging drawings
09/04/2020
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
cuidevices.com
很抱歉,暂时无法提供与“PJ-006B-SMT-TR”相匹配的价格&库存,您可以联系我们找货
