8
7
6
4
3
2
0.72
18.3
1.86
47.2
0.82
20.8
0.82
20.8
0.50
12.7
F
0.50
12.7
HANDLE
5/16-24 UNF 2A THREAD
TUBULAR INSULATOR
CENTER PIN TERMINAL (TIP)
CABLE CLAMP
SLEEVE TERMINAL
E
1
1.86
47.2
1.52
38.6
F
5
2.49
63.3
PLUG HANDLE I.D./
CABLE O.D. RANGE
SEE TABLE
2.49
63.3
0.97
24.7
TIP INSULATOR, BLUE
0.716
18.19
REF
0.26
6.6
FLOATING LOCKING RING
5/16-32 UNEF 2B THREAD
0.08 PIN I.D.
[2.0]
S1012, S1015, S1017
S10KS12, S10KS15, S10KS17
RUBBER SEAL HANDLE, NON-LOCKING, NON-SEALING PLUGS
RUBBER SEAL HANDLE, LOCKING, SEALING PLUGS
1.00
25.4
E
0.716
18.19
REF
0.218 REF
5.54
O-RING SEAL
D
0.97
24.7
1.86
47.2
0.82
20.8
D
1.86
47.2
0.82
20.8
0.38
9.5
2.04
51.8
C
2.04
51.8
0.98
24.9
C
0.98
24.9
0.716
18.19
REF
0.716
18.19
REF
0.218
5.54
B
B
S10
S10K
METAL HANDLE, NON-LOCKING, NON-SEALING PLUG
METAL HANDLE, LOCKING, NON-SEALING PLUG
NOTES:
1. HANDLE AND TUBULAR INSULATOR
SUPPLIED UNASSEMBLED.
A
2. MATERIAL:
CENTER CONTACT - COPPER ALLOY, SILVER PLATED
TERMINALS - COPPER ALLOY, TIN PLATED
PLUG BARREL - COPPER ALLOY, NICKEL PLATED
COUPLING RING - COPPER ALLOY, NICKEL PLATED
METAL HANDLE - COPPER ALLOY, NICKEL PLATED
RUBBER SEAL HANDLE - BLACK ELASTOMER
OVER METAL HANDLE
TIP INSULATOR - THERMOPLASTIC, BLUE
TERMINAL INSULATOR - PHENOLIC
TUBULAR INSULATOR - MYLAR
O-RING - ELASTOMER, BLACK
3. THESE PRODUCTS ARE RoHS COMPLIANT.
8
7
PART
NUMBER
S10
S10K
HANDLE
TYPE
CABLE O.D.
RANGE REF
METAL
UP TO 0.218"
S1012
0.125" - 0.150"
S1015
0.150" - 0.175"
S1017
S10KS12
RUBBER
SEAL
HANDLE
0.175" - 0.210"
0.125" - 0.150"
S10KS15
0.150" - 0.175"
S10KS17
0.175" - 0.210"
6
MATING POWER JACKS
CUSTOMER DRAWING
RAPC10S, RAPC10PS,
RASPC10S
RASH10S, RASH10PS
RASM10S, RASM10PS
RASSM10S
RAPC10, RAPC10P, RASPC10
RASH10, RASH10P
RASM10, RASM10P
RASSM10
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
UNLESS OTHERWISE SPECIFIED
1. ALL DIMENSIONS IN INCHES [mm]
0.02 [0.5]
- THREE PLACE DECIMALS
0.005 [0.13]
WIDTH
A
27139
ECO NUMBER
04/29/13
DATE
REVISIONS
4
PC
BY
02/16/12
DO NOT SCALE DRAWING
SolidWorks CAD File
NAME
C
LBS/M
TEMPER
MATERIAL
SPEC No.
FIRST USED ON
TJK
APVD
MULT
FINISH
DATE DRAWN
REV
5
- TWO PLACE DECIMALS
SIZE
BY
A
SPEC No.
SCALE
CHKD
PNK
PNK
02/16/12
2:1
APVD
SRC
01/16/12
S10 SERIES
POWER PLUGS, RoHS
SHEET
PART No.
1
OF
S10 SERIES
1
REV
A
很抱歉,暂时无法提供与“S1017”相匹配的价格&库存,您可以联系我们找货
