RASM10
RASM10
    SWITCHCRAFT
    CONN PWR JACK 2X6.4MM SMD
RASM10 数据手册
8 7 6 5 4 3 2 1 PCB LOCATING POST PART NUMBER SEAL O-RING 0.10 2.5 0.95 24.2 F RASM10 RASM10S RASM10P RASM10PS RASSM10 RASSM10S RASSM10P RASSM10PS 0.125 3.18 MAXIMUM PANEL THICKNESS 0.47 11.9 MOUNTING BUSHING 5/16-32 UNEF 2A THREAD 0.08 [2.0mm] CENTER PIN 0.35 9.0 0.055 1.40 NO YES NO YES NO YES NO YES TERMINAL PLATING NO SILVER YES F NO TIN YES 0.23 5.8 BUSHING I.D. CENTER PIN SHUNT 0.43 11.0 E A SLEEVE TERMINAL SLEEVE 0.26 6.5 SCHEMATIC SHUNT TERMINAL 0.08 2.0 0.07 1.7 0.06 1.6 0.062 1.57 0.19 4.9 0.325 8.26 0.60 15.2 HEX NUT SEE NOTE 1 CENTER PIN TERMINAL 0.054 1.36 E FLAT WASHER SEE NOTE 1 A SEAL O-RING NOT ALWAYS SUPPLIED SEE TABLE & NOTE 1 RASM10PS SHOWN HERE D 0.148 3.76 D 0.360 9.14 0.150 3.81 A 2X 0.180 4.57 SLEEVE TERMINAL 0.030 0.76 JACK MOUNTING SURFACE C SHUNT TERMINAL 0.03 0.9 0.283 7.19 SLEEVE SPRING TERMINAL SHUNT ABOVE REF 0.070 [1.78] MIN FOR CLEARANCE FIT 0.067 [1.70] MAX FOR INTERFERENCE FIT REQUIRED ONLY FOR JACKS WITH POST 0.321 8.15 2. MATERIAL: HOUSING, COVER: THERMOPLASTIC, BLACK MOUNTING BUSHING, HEX NUT: COPPER ALLOY, NICKEL PLATED CENTER PIN: COPPER ALLOY, NICKEL PLATED PIN AND SHUNT TERMINALS: COPPER ALLOY, SILVER OR TIN PLATED SLEEVE SPRING TERMINAL: SPRING COPPER ALLOY, SILVER OR TIN PLATED FLAT WASHER: STEEL, NICKEL PLATED O-RING: ELASTOMER, BLACK B RECOMMENDED PCB LAYOUT COMPONENT SIDE BELOW REF 0.004 0.10 SEE NOTE 3 DETAIL A SCALE 8 : 1 0.316±0.002 8.03±0.05 CUSTOMER DRAWING THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. UNLESS OTHERWISE SPECIFIED 3. HIGH POINT OR EDGE OF EACH OF THE THREE SOLDER TABS SHALL BE WITHIN A ZONE DEFINED BY COPLANARITY OF 0.004 INCH. SURFACE A SHALL BE 0.002 BELOW OR 0.010 ABOVE THE PLANE ESTABLISHED BY THE THREE HIGH POINTS OR EDGES OF THE THREE SOLDER TABS. 0.290±0.002 7.37±0.05 1. ALL DIMENSIONS IN INCHES [mm] - TWO PLACE DECIMALS 0.02 [0.5] - THREE PLACE DECIMALS 0.005 [0.13] SIZE A REV 27139 ECO NUMBER 04/29/13 DATE REVISIONS 6 5 4 PC BY 02/17/12 DO NOT SCALE DRAWING SolidWorks CAD File MULT NAME TEMPER BY A SPEC No. SCALE CHKD PNK PNK 02/17/12 4:1 APVD SRC 02/17/12 RA POWER JACKS, SMT HIGH AMP, 0.08 [2.0mm] PIN, RoHS C LBS/M MATERIAL SPEC No. FIRST USED ON TJK APVD WIDTH FINISH DATE DRAWN RECOMMENDED PANEL CUT-OUT 7 CENTER PIN TERMINAL 2X 0.250 6.35 1. HEX NUT, WASHER, AND O-RING (IF REQUIRED) SUPPLIED UNASSEMBLED. 8 C PIN 0.240 6.10 0.130 3.30 NOTES: 4. THESE PRODUCTS ARE RoHS COMPLIANT. 0.130 3.30 PCB LOCATING POST NOT ALWAYS PRESENT SEE TABLE 0.07 1.7 B A 0.160 4.06 1.05 26.7 REF PCB LOCATING POST SEE TABLE CENTER PIN TERMINAL SHUNT TERMINAL SLEEVE SHEET PART No. 1 OF RA_SM10 SERIES 1 REV A
RASM10 价格&库存
很抱歉,暂时无法提供与“RASM10”相匹配的价格&库存,您可以联系我们找货
