0.35
9.0
B
A
0.08 [2.0]
PIN DIA
A
LOCKING SHOULDER
10°
0.05
1.3
LOCKING GROOVE
0.57
14.5
0.25
6.3
0.43
11.0
0.26
6.5
B
0.13 TYP
3.4
0.10
2.5
0.08
2.0
A
0.008
0.2
0.06
1.6
0.04
1.1
0.03
0.8
SCHEMATIC
NOTES:
0.54
13.8
1. THIS PRODUCT IS RoHS COMPLIANT.
2. MATERIALS:
CENTER PIN: COPPER ALLOY, NICKEL PLATED
SLEEVE CONTACT: SPRING COPPER ALLOY, SILVER PLATED
PIN TERMINAL AND SHUNT: COPPER ALLOY, SILVER PLATED
HOUSING AND COVER: HIGH TEMPERATURE THERMOPLASTIC, BLACK
DETAIL A
0.59
14.9
SCALE 14 : 1
3. SPECIFICATIONS:
LIFE: 5000 CYCLES;
INSERTION FORCE: 5LB [2.3 KG] MAX;
WITHDRAWL FORCE: 0.5 LB [0.2 KG] MIN;
CONTACT RESISTANCE: 30 MILLIOHM MAX, 60 MILLIOHM MAX. AFTER TEST;
INSULATION RESISTANCE: 30 MEGAOHM MIN. @ 100VDC;
DIELECTRIC WITHSTANDING VOLTAGE: 250VAC FOR 1 MINUTE;
CURRENT (CARRYING): 5A
OPERATING TEMPERATURE: -30 C TO +65 C
0.001±0.003 TYP
0.04±0.08
0.27
6.8
0.18 TYP
4.6
0.67
17.1
DETAIL B
CUSTOMER DRAWING
SCALE 14 : 1
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
STAR SYMBOL DENOTES CRITICAL DIMENSION
UNLESS OTHERWISE SPECIFIED
SLEEVE
SHUNT
SLEEVE
CENTER PIN
0.03
0.6
0.07
1.7
CENTER PIN
SLEEVE SHUNT
SLEEVE
1°
0.10
2.5
0.42
10.7
0.27
6.9
SECTION A-A
0.02
0.5
0.29
7.5
0.02
0.5
0.20
5.1
0.10
2.4
1. ALL DIMENSIONS IN INCHES
B
28503
5/18/22
TJK
TJK
A
25775
1/22/07
BS
TJK
REV
ECO NUMBER
DATE
REVISIONS
BY
APVD
SIZE
WIDTH
MULT
FINISH
- TWO PLACE DECIMALS
0.02
- THREE PLACE DECIMALS
0.005
DO NOT SCALE DRAWING
SolidWorks CAD File
DATE DRAWN
BY
1/17/07
BS
B
TEMPER
MATERIAL
SPEC No.
FIRST USED ON
NAME
LBS/M
SPEC No.
SCALE
CHKD
TJK
08/20/08
4:1
APVD
TJK
08/20/08
LOCKING POWER JACK,
SH, 0.08 [2.0mm], RoHS
SHEET
PART No.
1
OF
2
RASH722BK
REV
B
0.189
4.80
0.189
4.80
0.025
0.64
0.130 *
3.30
0.025
0.64
CENTER
PIN
0.130 *
3.30
0.040
1.02
0.626
15.90
0.542
13.77
0.266
6.76
0.120
3.05
0.120
3.05
0.120
3.05
SLEEVE
0.294
7.47
0.160 *
4.06
0.030
0.76
0.044
1.12
0.250 *
6.35
0.050
1.27
0.160 *
4.06
0.050
1.27
CENTER
PIN
SLEEVE
SLEEVE
SHUNT
0.250 *
6.35
0.250 *
6.35
0.626
15.90
0.423
10.74
0.120
3.05
0.150 *
3.81
0.130 *
3.30
0.030
0.76
0.258
6.55
0.044
1.12
SLEEVE
SHUNT
0.542
13.77
0.294
7.47
SLEEVE
0.266
6.76
0.423
10.75
SLEEVE
0.150 *
3.81
0.130 *
3.30
0.258
6.55
0.265
6.73
0.250 *
6.35
0.265
6.73
JACK MATING FACE
(EDGE OF PC BOARD)
RECOMMENDED PC BOARD LAYOUT
(COMPONENT SIDE)
ALTERNATE PC BOARD LAYOUT
(COMPONENT SIDE)
CUSTOMER DRAWING
NOTE: * SURFACE MOUNT PADS.
SCALE
4:1
DATE DRAWN
08/20/08
DRAWN BY
SHEET
TOOL No.
OF
RASH722BK
BS
SolidWorks CAD File
2
B
2
REV
B
很抱歉,暂时无法提供与“RASH722BK”相匹配的价格&库存,您可以联系我们找货
