SJD-3512-45
SJD-3512-45
    CUIDEVICES
    CONN STEREO JACK 3.5MM 4/5P PCB
SJD-3512-45 数据手册
Product Page REV. A B C D 13.80 0.543 D 14.60 0.575 DESCRIPTION NEW DRAWING Added dimensions housing material change shield dimensions changed, pcb layout updated, plastic and terminal material corrected D 7.00 0.276 (2 PLCS) 3.60 0.142 (2 PLCS) 26.70 1.051 26.20 1.031 TI N 15.00 0.591 14.00 0.551 6.50 0.256 2.00X2.20 (2 PLCS) D 14.30 0.563 4.10 0.161 1.50 0.059 5L 2.50 0.098 IS C 5U 4L 3L 2L 1L 1U 5.00 0.197 4U 3U 1.25 0.049 5.00 0.197 10.00 0.394 1.50 0.059 (9 PLCS) 12.50 0.492 PCB LAYOUT TOP VIEW TERMINAL 1U TERMINAL 3U TERMINAL 4U TERMINAL 5U TERMINAL 1L TERMINAL 2L TERMINAL 3L TERMINAL 4L TERMINAL 5L FRONT SHIELD BACK SHIELD PC FILE NAME: SJD-3512-45 COPYRIGHT 2013 BY CUI INC. COVER HOUSING MATERIAL D Copper Alloy Copper Alloy Copper Alloy Copper Alloy Copper Alloy Copper Alloy Copper Alloy Copper Alloy Copper Alloy SPCC SPCC PBT PA-46 SCHEMATIC LOWER Scale: 1:1 SPECIFICATIONS: RATING: 16V DC @ 0.3A CONTACT RESISTANCE: 50m OHMS MAX INSULATION RESISTANCE: 100M OHMS MIN: 500V DC VOLTAGE WITHSTAND: 500V AC R.M.S. FOR 1 MINUTE LIFE: 5,000 CYCLES OPERATING TEMPERATURE: -25~85 C O 1.90 0.075 (2 PLCS) 6.00 0.236 UPPER 1.50 0.059 (2 PLCS) N 1.00 0.039 (9 PLCS) SJD-3512-45 MODEL NO. D 2.30 0.091 (2 PLCS) 1.50 0.059 (2 PLCS) 5/14/2013 U 2.40 0.094 DATE 12/15/2005 4/5/2006 2/9/2011 ED Additional Resources: 5U 1U 3U 4U 5L 1L 2L 3L 4L RoHS TOLERANCE: X.X ±0.3mm X.XX ±0.2mm PLATING Tin Tin Tin Tin Tin Tin Tin Tin Tin Nickel Nickel 20050 SW 112th Ave. Tualatin, OR 97062 Phone: 503-612-2300 800-275-4899 Fax: 503-612-2383 Website: www.cui.com TITLE: DUAL STACK 3.5mm STEREO JACK w/ SHLD PART NO. RDS D UNITS: SJD-3512-45 DRAWN BY: REV: MM [INCHES] APPROVED BY: SCALE: 2:1
SJD-3512-45 价格&库存
很抱歉,暂时无法提供与“SJD-3512-45”相匹配的价格&库存,您可以联系我们找货
