SJ-43502PM
SJ-43502PM
    CUIDEVICES
    CONN JACK AUDIO 3.5MM 4COND
SJ-43502PM 数据手册
REV. A B C D DESCRIPTION NEW DRAWING Added pin tolerances added hole dimensions for output terminals material list update 1.5 0.059 3.6 0.142 4.5 0.177 4.0 0.157 10.2 0.402 1.25 0.049 9.0 0.354 10.0 0.394 8.0 0.315 3.0 0.118 M7X0.75 DATE 11/9/2005 8/31/2006 6/2/2008 8/7/2008 1.0 0.039 2.00 0.079 0.15 7.7 0.304 2.5 0.099 3.0 0.118 (2 PLCS) 2.6 0.102 2 3 1.0 0.039 0.9 0.035 (2 PLCS) 4 0.8 0.031 0.8 0.031 (2 PLCS) 1 0.15 2.6 0.102 2.0 0.079 (4 PLCS) A 0.1 A MODEL NO. SCHEMATIC SJ-43502PM 4 3 2 1 PC FILE NAME: SJ-43502PM COPYRIGHT 2008 BY CUI INC. MATERIAL PLATING Nickel Gold Nickel TERMINAL 3 Steel Copper Alloy Copper Alloy Copper Alloy TERMINAL 4 HOUSING Brass PBT HEX NUT TERMINAL 1 TERMINAL 2 SECTION A-A SCALE 3 : 1 RoHS TOLERANCE: ±0.3mm UNLESS OTHERWISE SPECIFIED SPECIFICATIONS: RATING: 34V DC or 34V AC@ 1A CONTACT RESISTANCE: 50m OHMS MAX INSULATION RESISTANCE: 100M OHMS MIN: 500V DC VOLTAGE WITHSTAND: 500V AC R.M.S. FOR 1 MINUTE LIFE: 5,000 CYCLES OPERATING TEMP: -20 to 70C Nickel Nickel 0.15 20050 SW 112th Ave. Tualatin, OR 97062 Phone: 503-612-2300 800-275-4899 Fax: 503-612-2383 Website: www.cui.com TITLE: 3.5mm Panel Mount Audio Jack - 4 Connector PART NO. UNITS: SJ-43502PM DRAWN BY: ZRJ APPROVED BY: REV: D MM [INCHES] SCALE: 3:1
SJ-43502PM 价格&库存
很抱歉,暂时无法提供与“SJ-43502PM”相匹配的价格&库存,您可以联系我们找货
