Specifications for UHF Connectors
_____________________________
UHF style connectors are inexpensive, general purpose connectors with non-constant impedance for use at
500 volts or less, and for use with low frequencies to 200Mhz for best performance, or to 500MHz but with
diminished performance. These coaxial connectors are widely used in citizens band communications,
CCTV, public address systems, mobile radio equipment, civil defense, ship to shore communications,
antenna connections, landing systems, and ground control apparatus. UHF connectors use a 5/8-24 threaded
coupling. They are available in a wide selection of sizes to fit various cable sizes.
s
MATERIALS
Connector Parts
Connector Body and Parts
Male Contact Pin
Outer Contact
Crimp Ferrule
Insulators,
Plating
Material
Brass
Brass
Brass
Annealed Copper
Delrin, Teflon
Nickel
ELECTRICAL
Requirement
Impedance
Frequency Range
VSWR
Working Voltage (At Sea
level)
Insulation Resistance
Contact Resistance
Test Voltage
Performance
Non Constant
0-500MHz
1.25 Max.
750V rms
5000 Megohm Min.
5mW Max.
2000V rms
MECHANICAL & ENVIRONMENTAL
Requirement
Durability
Performance
500 Matings
RG58 - 60 Lb. Min.
Cable Retention (Cable Types) RG59 - 75 Lb. Min.
RG8, 213 - 150 Lb. Min.
Coupling Nut
45 lbs. Maximum
Delrin: -55 to +85°C
Temperature Range
Teflon: -55 to +200°C
s
22
FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111
s
- Page 23 -
UHF Connectors
Crimp Plugs
UHF cable plugs are available in two-piece crimp and older versions. Several cable diameters are facilitated
with these connectors for applicable applications. A reducing adapter is used for smaller cable sizes when
using the solder types.
Part Number
RG/U Fig.
Cable No.
Description
710A205F
Crimp Plug
58
106
710A205G
Crimp Plug
59, 62
106
8, 213
107
58
108
58
108
710A908B
Twist/Solder Plug, PL259
Reducing Adapter,
UG175/U
770A508F
Reducing Adapter,
UG176/U
770A508G
RoHS compliant
DRAWING
REQUEST QUOTE
Fig. 106
Fig. 107
REQUEST
Fig. 108
Jacks
Two panel jack style are available as standard items. These panel jacks will facilitate any cable size by
soldering the center conductor to the connector’s solder-cup contact.
Part
Number
Description
726A508
Bulkhead Jack
Any
109
727A508
Panel Jack, SO239 Type
Any
110
RoHS compliant REQUEST QUOTE
DRAWING
Fig. 109
Fig. 110
RG/U Fig.
Cable No.
REQUEST
s
Adapters
Standard configurations of adapters are machined brass with attractive nickel plating. All contacts are gold
plated brass (males) and phosphor bronze (females).
Part Number
731A505
Description
Male/Male
Fig.
No.
111
732A508
Female/Female Inline
112
735A504
743A508
Female/Female, Bulkhead
F/M/F “T” Adapter
113
114
745A508
F/F/F “T” Adapter
115
751A505
F/M Right Angle Adapter
116
RoHS compliant
DRAWING
REQUEST QUOTE
REQUEST
Fig. 111
Fig. 112
Fig. 113
Fig. 114
Fig. 115
Fig. 116
s
Back to Index
23
很抱歉,暂时无法提供与“710A908B”相匹配的价格&库存,您可以联系我们找货
