- Page 24 -
Specifications for "F" Connectors
_____________________________
F style connectors are the least expensive, general purpose connectors with non-constant impedance for use at 500 volts or
less, and for use with low frequencies to 500Mhz. These coaxial connectors are widely used in Cable TV, MATV, CCTV,
and related consumer television products. They are available in a limited selection to fit various cable sizes. NOTE: See
V-Bite 861V509ER6 -40dB @ 2.3GHz
MATERIALS
Connector Parts
Connector Body and Parts
Male Contact Pin
Insulators
Plating
Ferrule
Material
Brass
Brass
Polypropylene
Nickel
Annealed Copper
ELECTRICAL
Requirement
Impedance
Frequency Range
VSWR
Working Voltage (At Sea level)
Insulation Resistance
Contact Resistance
Test Voltage
Performance
Non Constant
0-500MHz (see below
861V509ER6 to 3GHz)
1.5 Max.
500V rms
5000 Megohm Min.
3 mW Max.
1000V r.m.s
MECHANICAL & ENVIRONMENTAL
Requirement
Durability
Shock
Cable Retention
Temperature Range
Moisture Range
Performance
500 Matings
30 G
40 Lbs. Min.
-40 to +65°C.
Continuous Test
s
FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111
back to index
24
- Page 25 -
"F" Connectors
Plugs, Jacks, Adapters
F type plugs are available in three different crimp styles: two piece with separate ferrules, one piece crimp with a short
crimp body and a one piece crimp with a long body. Also, a twist-on type for tool-less installations. Jacks for bulkhead,
inline, or PC board, and a variety of adapters are all machined brass construction.
Part Number
Description
810A209A
810A209D
810A209G
810B209G
810D209A
810A209MV
810D209D
810D209G
810E209A
810E209D
810E209G
810A409A
810A409G
810P209A
810P209G
816B519
826B519
832A519N
830A509
831B509
832A519
843A509
845A509
851A509
F0884
2 Piece Crimp Plug, Short Ferrule
2 Piece Crimp Plug, Long Ferrule
4 Pc Crimp Mini Coax. Uses BD11007 Tool
1 Piece Crimp Plug, Short Ferrule
1 Piece Crimp Plug, Long Ferrule
Twist-On
Twist-On
Push-On
Push-On
Male Bulkhead Receptacle. 3/8-32 THD I.D.
Bulkhead Jack, Solder Tab
Inline Female/Female W/Nut &Washer
Inline, Male/Male
Inline Female/Male Push-On
“T” Adapter, Female/Male/Female
“T” Adapter, Female/Female/Female
Right Angle Adapter, Male/Female
75 Ohm Male Terminator
RoHS compliant
REQUEST QUOTE
RG/U
Cable
6
11
59
59
6
174
11
59
6
11
59
6
59
6
59
Any
Any
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
Fig.
No.
117
117
117
118
117
117A
119
119
120
120
120
121
121
122
122
130A
123
124
125
125A
126
127
128
129
130
Fig. 117
Fig. 117A
Fig. 118
Fig. 119
Fig. 120
Fig. 121
Also See Push-EZ™ Next Page
Fig. 122
Fig. 123
Fig. 124
Adapters & Terminators
REQUEST DRAWING
Fig. 125
Fig. 127
Fig. 126
Fig. 125A
Fig. 128
s
This recessed male acts as a jack & allows for a
replaceable female end by using a 832A519 adapter.
Also, this can be used to accommodate any adapter with
a female F interface on one side. The other end can be
BNC, TNC, or any style available. (See adapter pages)
Fig. 129
ss
Fig. 130A2
3/8 - 32 Internal Thd. ½ - External Thd.
s
Fig. 130
s
back to index
25
- Page 26 -
Push EZ™ “F” Plugs With LIFT™
Bomar’s exclusive LIFT® Technology (Low Insertion Force
Termination) is used in the patented Push-EZ™ connector. It installs
by simply stripping the cable and inserting it into the connector.
That’s it. And it will not pull out.
No crimp tooling required.
s
Part
Number
810PE209A
810PE209G
810PE205A
810PE205G
RG/U Body
Cable Plating
Description
Push-EZ™ Plug with LIFT® Technology
RoHS compliant
REQUEST QUOTE
6
59
6
59
Nickel
Nickel
Gold
Gold
REQUEST DRAWING
PC Board Connectors
Part
Number
861A509
861V509E
861V509ER
861V509ER6
864B509
864B509HF
864B509S
866B509
Description
PC Board Jack, Vertical
V-Bite™ Edge Mount PC Jack
V-Bite™ Reflow Type w/ TFE Insulator RG59
V-Bite™ Reflow Type w/ TFE Insulator RG6/59
(3GHz)
PC Board Jack, Right Angle, Long
PC Board Jack, Right Angle, Long (3GHz)
PC Board Jack, Right Angle, Short
PC Board Male, Right Angle The Eliminator™
RoHS compliant reflow or wave solder
only
REQUEST QUOTE
RG/U Fig.
Cable No.
N/A
N/A
N/A
131
131V
131V
N/A
131V
N/A
N/A
N/A
N/A
132
132
133
136B
RoHS compliant wave solder
REQUEST DRAWING
Fig. 131
Fig. 132
Fig. 133
Fig. 135B
The V-Bite™
V-Bite™ Mounts on the PC board edge and is
extremely anti-rotational. It locks into the board for
soldering. Available in reflow soldering version.
Fig. 131V
V-Bite™
Mounts
on the PC
board
edge and
is
extremely
antirotational.
It locks
into the
board for
soldering.
Available
in reflow
soldering
version.
PCB Layout 864B Series
- Page 27 -
back to index
26
很抱歉,暂时无法提供与“864B509HF”相匹配的价格&库存,您可以联系我们找货
