MCX Crimp Type Right Angle Plugs for Flexible Cable
1. Identify connector parts. (4 piece parts).
2. Strip cable to dimensions shown. Do not nick braid or center
conductor. A wire stripper of correct size is recommended for
this step. Twist stranded center conductor into tight bundle and
tin (optional). Slide crimp sleeve onto cable as shown.
3. Flare braid and slide cable into body making certain that the
cable dielectric bottoms against center contact. Solder: Solder
center conductor to contact through the side access ports and
hole in center contact. Use a minimum amount of solder for a full
fillet joint. .015 (0.38) diameter solder is recommended. Crimp:
Crimp Contact Attachment Crimp contact using 41-0000-924
dieset in 144-0000-900 tool frame.
4. Arrange braid uniformly around crimp stem. Slide crimp sleeve
over braid and access ports. Crimp securely using recommended
hex size and crimp tool.
Cable Group
Part No.
Sleeve Hex
RG-316/U, 188, 174
133-9403-101/104
.128 (3.25)
RG-316 DS, 188 DS
133-9404-101
.151 (3.83)
RG-178
133-9402-101
.105 (2.67)
228
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“133-9404-101”相匹配的价格&库存,您可以联系我们找货
