SF1211-6044
SF1211-6044
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPPLUGSTR50OHMPCB
SF1211-6044 数据手册
PRODUCT DATA DRAWING ROHS COMPLIANT SMP LIMITED DETENT INTERFACE PER MIL-STD-348 .182 4.62 01 5X .090 2.29 2X .100 2.54 4X .020±.003 0.51±0.08 MATERIAL: INSULATOR: APPROVED 0 +.000 3.05 .120 - 0.08 - .003 .027±.001 0.69±0.03 NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com PC LEGS BODY & CONTACT: DATE 03/10 PRELIMINARY 0 +.000 3.01 .120 - 0.08 - .003 .218 5.54 INTERFACE BODY: REVISION HISTORY DESCRIPTION REV STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 4X .038±.001 0.97±0.03 BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 2X .050 1.27 PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B FINISH: INTERFACE BODY: PC LEGS BODY & CONTACT: PASSIVATED PER AMS-2700 GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27; OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: DWV: OPERATING TEMP.: .0325±.0015 0.83±0.04 RECOMMENDED MOUNTING HOLE PATTERN MATERIAL: FINISH: 50 OHMS DC TO 40.0 GHz 325 VRMS -55 C TO +125 C SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 .030 .010 .005 ANGULAR: X X X' 1 0' 15' INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: CHECKED: APPROVED: DAL 03/25/10 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMP MALE PC MOUNT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 15:1 SF1211-6044 SHEET 1 OF 1
SF1211-6044 价格&库存
很抱歉,暂时无法提供与“SF1211-6044”相匹配的价格&库存,您可以联系我们找货
