2985-6036
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMARCPTSTR50OHMEDGEMNT
2985-6036 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING - .187 4.75 BODY & CONTACT .375 9.53 REVISION HISTORY DESCRIPTION REV .065 1.65 DCN 38497 DATE APPROVED 08/11 PJS .375 9.53 2X .040 1.02 2X .040 1.02 .312 7.92 2X "A" 1/4-36 UNS-2A 2X "B" .030 0.76 MATERIAL: BODY: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: INSULATOR: PART No. BOARD THICKNESS DIMENSION "A" DIMENSION "B" BERYLLIUM COPPER PER ASTM B-196, ALLOY UNS C17300, TD04 2985-6035 .062 (1.57) .068/.064 (1.67) .073 (1.85) PTFE PER ASTM D-1710, TYPE I, GRADE 1, CLASS B 2985-6036 .042 (1.07) .048/.044 (1.16) .093 (2.36) 2985-6037 .031 (0.79) .037/.033 (0.88) .104 (2.64) 2985-6038 .093 (2.36) .099/.095 (2.46) .042 (1.07) FINISHES: BODY & CONTACT: GOLD PER ASTM B-488, TYPE II, CODE C, CLASS 1.27 OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00010" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: INSUL. RESIST.: DWV: VSWR: 50 OHMS DC-18 GHz 5000 MEGOHMS, MIN. 1000 VRMS N/A NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com MATERIAL: SEE NOTES DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: FINISH: SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE AFTER PLATING. 2) BREAK CORNERS & EDGES .005 R. MAX. 3) CHAM. 1ST & LAST THREADS. 4) SURFACE ROUGHNESS 63 MIL-STD-10. 5) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN T.I.R. 6) REMOVE ALL BURRS DRAWN: FED 08/25/11 CHECKED: APPROVED: PJS 08/25/11 PJS 08/25/11 E.M. SIMULATION: N/A SV Microwave, Inc. 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMA JACK END LAUNCH RECEPTACLE SIZE CAGE CODE DWG. NO. 2985-6035-6038 B 95077 SCALE: 5:1 SHEET 1 OF 1
2985-6036 价格&库存
很抱歉,暂时无法提供与“2985-6036”相匹配的价格&库存,您可以联系我们找货
