ROHS COMPLIANT
PRODUCT DATA DRAWING
ALIGNMENT PLUG
DISCARD AFTER INSTALLATION
.058 1.47
REVISION HISTORY
DESCRIPTION
REV
DCN 38507
DATE
APPROVED
08/11
STW
.085 2.16
2X
.009 0.23
.090 2.29
.019 0.48
.026 0.66
.049±.001 1.24±0.03
RP
NOTES:
1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOU
PCB, PLEASE CONTACT US AT applications@svmicro.com
.012 0.30 THRU
MATERIAL:
.090 2.29
BODY & CONTACT:
BERYLLIUM COPPER PER ASTM B196,
ALLOY No. UNS C17300, TD04.
ALIGNMENT PLUG:
PTFE PER ASTM D1710
.043 1.09
SOLDER AREA
FINISH:
BODY & CONTACT:
RECOMMENDED PCB LAYOUT
GOLD PER ASTM B488, TYPE II,
CODE C, CLASS 1.27, OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00005" MIN.
MATERIAL:
PERFORMANCE:
FINISH:
IMPEDANCE:
OPERATING TEMP.:
50 OHMS.
-55 C TO +125 C.
SEE NOTES
SEE NOTES
SURFACE AREA:
N/A
PROPRIETARY
ENGAGEMENT:
DISENGAGEMENT:
3.5 LBS TYPICAL.
2.0 LBS TYPICAL.
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
FSG 08/29/11
CHECKED:
APPROVED:
STW 08/29/11
STW 08/29/11
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
SMPS FD MALE
SURFACE MOUNT
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 30:1
3811-40006
SHEET 1 OF 1
很抱歉,暂时无法提供与“3811-40006”相匹配的价格&库存,您可以联系我们找货
