3811-40005
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPSPLUGSTR50OHMSMD
3811-40005 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING ALIGNMENT PLUG DISCARD AFTER INSTALLATION .058 1.47 REVISION HISTORY DESCRIPTION REV DATE APPROVED A ADDED CONTACT DIMENSIONS 05/10 DAL B REV. DCN 37673 07/26/10 PJS C REV. DDCN 40056 09/12/13 STW .085 2.16 2X .009 0.23 .090 2.29 .019 0.48 .026 0.66 .049±.001 1.24±0.03 RP NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOU PCB, PLEASE CONTACT US AT applications@svmicro.com .012 0.30 THRU MATERIAL: BODY & CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04. ALIGNMENT PLUG: PTFE PER ASTM D1710 .090 2.29 .043 1.09 FINISH: BODY & CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: OPERATING TEMP.: ENGAGEMENT: DISENGAGEMENT: SOLDER AREA RECOMMENDED PCB LAYOUT MATERIAL: 50 OHMS. -55 C TO +125 C. 1.6 LBS TYPICAL. 0.50 LBS TYPICAL. FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: JMC 12/18/09 CHECKED: APPROVED: STW 05/03/10 STW 05/03/10 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPS SB MALE SURFACE MOUNT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 30:1 3811-40005 SHEET 1 OF 1
3811-40005 价格&库存
很抱歉,暂时无法提供与“3811-40005”相匹配的价格&库存,您可以联系我们找货
