ECP.01.250.NLL
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
01
Termination type
Female solder
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
0.00 - 0.00 mm
Status
active
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
ECP.01*: Fixed receptacle, nut fixing (back panel mounting)
Keying
Circular, female
Housing Material
Brass (nickel plated [SAE AMS QQ N 290]) shell, collet nut, latch sleeve and mid pieces
Weight
1.04 g
Performance
Configuration
01.250 : 1 Coax (50 Ohm)
Insulator
Rated Current
Specifications
Contact Type: Solder
Others
Endurance (Shell): 1000 mating cycles
Salt Spray Corrosion: >144 hr
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
DRAWINGS
Dimensions
A
Emax
L
M
e
mm.
7
3.5
10.5
5.7
M5x0.5
in.
0,28
0,14
0,41
0,22
RECOMMENDED BY LEMO
Tools
2/2
很抱歉,暂时无法提供与“ECP.01.250.NLL”相匹配的价格&库存,您可以联系我们找货
