PRODUCT DATA DRAWING
.200
REVISION HISTORY
DESCRIPTION
DATE
APPROVED
A
DCN 49789
04/20
STW
B
DCN 50989
08/21
STW
REV
3X .090
2X .040 1.02
.015 0.38
INTERFACE PER
MIL-STD-348
SEE TABLE
.250 6.35
.171 4.34
2X .074
2X .015 0.38
2X .0075
BODY:
STAINLESS STEEL PER AMS-5640,
ALLOY No. UNS S30300, TYPE 1
CONTACT:
BERYLLIUM COPPER PER ASTM B196,
ALLOY No. UNS C17300, TD04
INSULATOR:
PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B
FINISH:
BODY &
CONTACT:
GOLD PER ASTM B488, TYPE II, CODE C
CLASS 1.27 OVER NICKEL PER AMS-QQ-N-290
.160 4.06
NOTES:
1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR
PCB, PLEASE CONTACT US AT applications@svmicro.com
MATERIAL:
FINISH:
PERFORMANCE:
IMPEDANCE:
FREQ. RANGE:
INSUL. RES.:
.090±.002
RP
MATERIAL:
50 OHMS
DC TO 18.0 GHz
5000 MEGOHMS, MIN.
SEE NOTES
SEE NOTES
SURFACE AREA:
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
.030
.010
.005
ANGULAR: X
X X'
1 0'
15'
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
PART NUMBER
1211-66137
1211-66138
1211-66139
INTERFACE
FULL DETENT
LIMITED DETENT
SMOOTH BORE
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
JMC 03/10/10
CHECKED:
APPROVED:
PJS 03/10/10
PJS 03/10/10
www.svmicrowave.com
TITLE:
SMP MALE EDGE MT
SIZE DWG. NO.
B
SCALE: 16:1
1211-66137-66139
SHEET 1 OF 1
很抱歉,暂时无法提供与“1211-66138”相匹配的价格&库存,您可以联系我们找货
