1411-60007
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNBMMAPLUGSTR50OHMEDGEMNT
1411-60007 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING 01 PRELIMINARY DATE APPROVED 08/10 STW .250 6.35 .343 8.71 .155 3.94 2X .040 1.02 2X .034 0.86 .301 7.65 .117 2.97 .034 0.86 .034 0.86 MATERIAL: BODY: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BRASS PER ASTM B16, ALLOY UNS No. C36000 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B O-RING: FLUOROSILICONE NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com FINISH: BODY & CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. FINISH: SEE NOTES SEE NOTES SURFACE AREA: PERFORMANCE: IMPEDANCE: MATERIAL: N/A PROPRIETARY 50 OHMS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 .030 .010 .005 ANGULAR: X X X' 1 0' 15' INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: DAL 08/04/10 CHECKED: APPROVED: STW 08/04/10 STW 08/04/10 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: BMMA MALE EDGE MOUNT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 9:1 1411-60007 SHEET 1 OF 1
1411-60007 价格&库存
很抱歉,暂时无法提供与“1411-60007”相匹配的价格&库存,您可以联系我们找货
