ROHS COMPLIANT
PRODUCT DATA DRAWING
.187 4.75
BODY & CONTACT
.375 9.53
REVISION HISTORY
DESCRIPTION
REV
.065 1.65
DCN 38497
DATE
APPROVED
08/11
PJS
.375 9.53
2X .040 1.02
2X .040 1.02
.312 7.92
2X "A"
1/4-36 UNS-2A
2X "B"
.030 0.76
MATERIAL:
BODY:
STAINLESS STEEL PER AMS-5640,
ALLOY UNS S30300, TYPE 1
CONTACT:
INSULATOR:
PART No.
BOARD
THICKNESS
DIMENSION
"A"
DIMENSION
"B"
BERYLLIUM COPPER PER ASTM B-196,
ALLOY UNS C17300, TD04
2985-6035
.062 (1.57)
.068/.064 (1.67)
.073 (1.85)
PTFE PER ASTM D-1710, TYPE I, GRADE 1, CLASS B
2985-6036
.042 (1.07)
.048/.044 (1.16)
.093 (2.36)
2985-6037
.031 (0.79)
.037/.033 (0.88)
.104 (2.64)
2985-6038
.093 (2.36)
.099/.095 (2.46)
.042 (1.07)
FINISHES:
BODY &
CONTACT:
GOLD PER ASTM B-488, TYPE II, CODE C,
CLASS 1.27 OVER NICKEL PER AMS-QQ-N-290,
CLASS 1, .00010" MIN.
PERFORMANCE:
IMPEDANCE:
FREQ. RANGE:
INSUL. RESIST.:
DWV:
VSWR:
50 OHMS
DC-18 GHz
5000 MEGOHMS, MIN.
1000 VRMS
N/A
NOTES:
1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE
CONTACT US AT applications@svmicro.com
MATERIAL:
SEE NOTES
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
FINISH:
SEE NOTES
SURFACE AREA:
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE AFTER PLATING.
2) BREAK CORNERS & EDGES .005 R. MAX.
3) CHAM. 1ST & LAST THREADS.
4) SURFACE ROUGHNESS 63 MIL-STD-10.
5) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN T.I.R.
6) REMOVE ALL BURRS
DRAWN:
FED 08/25/11
CHECKED:
APPROVED:
PJS 08/25/11
PJS 08/25/11
E.M. SIMULATION: N/A
SV Microwave, Inc.
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
SMA JACK END LAUNCH
RECEPTACLE
SIZE CAGE CODE DWG. NO.
2985-6035-6038
B 95077
SCALE: 5:1
SHEET 1 OF 1
很抱歉,暂时无法提供与“2985-6035”相匹配的价格&库存,您可以联系我们找货
