HEP.00.250.NTNP
HEP.00.250.NTNP
    LEMO(雷莫)
    CONN JACK STR 50 OHM PCB
HEP.00.250.NTNP 数据手册
HEP.00.250.NTNP www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Female print PCB IP rating 68 when mated AWG wire size 0.00 - 0.00 PCB Altium Pattern Cable Ø 0.00 - 0.00 mm PCB KiCad Pattern Status active Catalog Download Request a quote PCB Eagle Pattern TECHNICAL DETAILS Mechanics Shell Style/Model HEP*: Fixed receptacle, nut fixing, watertight for printed circuit Keying Circular, female Housing Material Brass (nickel plated [SAE AMS QQ N 290]) shell, collet nut, latch sleeve and mid pieces Variant P : Watertight unmated Weight 7.39 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm (Printed Circuit Board) Contact Dia.: 0.7 mm (0.028in) Test voltage: 2.1 kV (rms) R (max): 6.1 mOhm Vtest: 2100 V (AC), 3000 V (DC) Impedance: 50 Ohm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 VSWR: 1.09 + 0.11 * f/GHz Others Endurance (Shell): 5000 mating cycles Temp (min / max): -20°C / +100°C F ret (min): 100 N Salt Spray Corrosion: >144 hr Pressure: 60 bars DRAWINGS Dimensions A Emax L e mm. 11 2 18 M7x0.5 in. 0,43 0,08 0,71 RECOMMENDED BY LEMO Tools Spanner wrench: Socket for torque wrench DCM.00.M07.4 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
HEP.00.250.NTNP 价格&库存
很抱歉,暂时无法提供与“HEP.00.250.NTNP”相匹配的价格&库存,您可以联系我们找货
