SF1552-6002
SF1552-6002
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONN2.92MMJKSTR50OHMCOMPRES
SF1552-6002 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING A DCN 41727 DATE APPROVED 10/15 DAL .384 9.75 .222 5.64 .009±.003 0.23±0.08 ACCEPTS Ø.012±.001 X .055 MAX LONG PIN .481 12.22 MATERIAL: BODY & INSERT: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 BEAD: ULTEM 1000 PER ASTM D5205 .625 15.88 4X .103±.003 2.62±0.08 THRU HOLES .065 1.65 FINISH: BODY & INSERT: PASSIVATED PER AMS-2700 CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS .76, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: MATERIAL: FINISH: 50 OHMS DC TO 40.0 GHz SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: BRT 09/08/02 CHECKED: APPROVED: DWC 09/12/02 DWC 09/12/02 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SVK JACK 2 HOLE FLANGE MOUNT W/ REAR FEMALE CONTACT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 6:1 SF1552-6002 SHEET 1 OF 1
SF1552-6002 价格&库存
很抱歉,暂时无法提供与“SF1552-6002”相匹配的价格&库存,您可以联系我们找货
