5050-0042
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNNJACKSTR50OHMSOLDER
5050-0042 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING B .687 17.45 .736 18.69 .500 12.70 .075 1.91 DCN 41709 DATE APPROVED 09/15 FED .100 2.53 .005±.001 0.13±0.03 X .050 WIDE TAB 4X .1275±.0025 3.24±0.06 EPOXY CAPTIVATION 5/8-24 UNEF-2A MATERIAL: BODY: BRASS PER ASTM B16, ALLOY UNS No. C36000 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B FINISH: BODY: NICKEL PER AMS-2404 CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 0.76, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: IMPEDANCE: FREQ. RANGE: DWV: 50 OHMS DC TO 12.4 GHz 3000 VRMS N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: DAL 09/28/15 CHECKED: APPROVED: ND 09/19/80 DGG 09/19/80 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: N JACK 4 HOLE FLANGE MOUNT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 3.5:1 5050-0042 SHEET 1 OF 1
5050-0042 价格&库存
很抱歉,暂时无法提供与“5050-0042”相匹配的价格&库存,您可以联系我们找货
