ROHS COMPLIANT
PRODUCT DATA DRAWING
REVISION HISTORY
DESCRIPTION
REV
NRN 37567
DATE
APPROVED
08/12
STW
4X .216 5.49
2X
.100 2.54
4X
.106±.002 2.69±0.05
RP
4X
.125 3.18
.218 5.54
4X
.025 0.64
.169 4.29
.060 1.52
.015 0.37
RECOMMENDED MOUNTING HOLE
MATERIAL:
.030±.002 0.76±0.05
BODY:
STAINLESS STEEL PER AMS-5640,
ALLOY UNS S30300, TYPE 1
CONTACT &
LEGS:
BERYLLIUM COPPER PER ASTM B196, ALLOY UNS C17300
INSULATOR:
TORLON 4203 (ELECTRICAL GRADE)
.100±.002 2.54±0.05
FINISH:
BODY:
CONTACT &
LEGS:
PASSIVATED PER AMS-2700
GOLD PER ASTM B488, TYPE II,
CODE C, CLASS 1.27, OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00005" MIN.
MATERIAL:
FINISH:
PERFORMANCE:
IMPEDANCE:
FREQ. RANGE:
VSWR:
NOTES:
1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE
CONTACT US AT applications@svmicro.com
SEE NOTES
SEE NOTES
SURFACE AREA:
50 OHMS
DC TO 20.0 GHz
1.30:1 DC TO 20.0 GHz
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
.030
.010
.005
ANGULAR: X
X X'
1 0'
15'
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
SV P/N
SF1211-66198
SF1211-66199
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
ELA 04/27/12
CHECKED:
APPROVED:
STW 04/27/12
STW 04/27/12
SMP INTERFACE
LD
FD
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
SMP MALE PCB MOUNT W/
R/A CONTACT (LD, FD)
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 13:1
SF1211-66198-66199
SHEET 1 OF 1
很抱歉,暂时无法提供与“SF1211-66198”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+241.101581+29.14578
- 10+229.4416010+27.73625
