ROHS COMPLIANT
PRODUCT DATA DRAWING
REVISION HISTORY
DESCRIPTION
REV
.669±.008 17±0.20
HEX.
DCN 41023
DATE
APPROVED
01/15
STW
.098±.008 2.50±0.20
1/2-28 UNEF- 2A
7/16-28 UNEF-2A
.437±.008 11.10±0.20
ACROSS FLATS
.669±.008 17±0.2
.445 MIN
.886 22.50
MATERIAL:
BODY:
BRASS
CONTACT:
BERYLLIUM COPPER
INSULATOR:
PTFE
.500
MIN
RECOMMENDED MOUNTING HOLE
FINISH:
BODY:
TERNARY-ALLOY
CONTACT:
GOLD
MATERIAL:
FINISH:
PERFORMANCE:
OPERATING TEMP.:
SEE NOTES
SEE NOTES
SURFACE AREA:
-45 C TO +120 C
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
MAL 01/07/15
CHECKED:
APPROVED:
STW 01/07/15
STW 01/07/15
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
SIZE
B
TNC JACK BULKHEAD
FOR .085 (SOLDER)
CAGE CODE DWG. NO.
4021-00064
95077
SCALE: 4:1
SHEET 1 OF 1
很抱歉,暂时无法提供与“4021-00064”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+504.457501+64.24920
- 10+462.9772010+58.96610
- 25+445.1699025+56.69810
- 50+406.1269050+51.72550
- 100+377.57930100+48.08960
- 250+370.78060250+47.22370
