ROHS COMPLIANT
PRODUCT DATA DRAWING
REVISION HISTORY
DESCRIPTION
DATE
APPROVED
DCN 38469
08/11
STW
A
NRN 40649
05/16
STW
B
DCN 49690
03/20
DMS
REV
2X
.165 4.19
RP
.140 3.56
.290 7.37
.090 2.29
.230 5.84
.180 4.57
5X .090 2.29
2X .065 1.65
2X
.015 0.38
2X .160 4.06
.360±.010 9.14±0.25
.490 12.45
SV PART NUMBER COUPLING STYLE
9311-60033
SMOOTH BORE
9311-60034
LIMITED DETENT
9311-60035
FULL DETENT
.192 4.88
MATERIAL:
BODY & SHROUDS:
STAINLESS STEEL PER AMS-5640,
ALLOY UNS S30300, TYPE 1
CONTACTS:
BERYLLIUM COPPER PER ASTM B196,
ALLOY No. UNS C17300, TD04
INSULATORS:
3X .104 2.63
3X .0075±.0010 0.19±0.03
3X .015 0.38
2X
.200±.002 5.08±0.05
2X .100 2.54
PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B
.0725±.0010 1.84±0.03
.400±.004 10.16±0.10
FINISH:
BODY, SHROUDS
& CONTACTS:
GOLD PER ASTM B488, TYPE II,
CODE C, CLASS 1.27, OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00005" MIN.
MATERIAL:
FINISH:
PERFORMANCE:
IMPEDANCE:
FREQ. RANGE:
NOTES:
1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE
CONTACT US AT applications@svmicro.com
SEE NOTES
SEE NOTES
SURFACE AREA:
50 OHMS
DC TO 26.5 GHz.
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
.030
.010
.005
ANGULAR: X
X X'
1 0'
15'
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
FSG 08/16/11
CHECKED:
APPROVED:
STW 08/16/11
STW 08/16/11
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
SIZE
B
SMP FD MALE 2-PORT
PCB EDGE MOUNT
DWG. NO.
SCALE: 8:1
9311-60033-60035
SHEET 1 OF 2
ROHS COMPLIANT
REVISION HISTORY
DESCRIPTION
DATE
APPROVED
DCN 38469
08/11
STW
A
NRN 40649
05/16
STW
B
DCN 49690
03/20
DMS
REV
.140 3.56
2X ZERO CORNER BREAK:
ENSURE ZERO TO NO
RADIUS SO CONNECTOR
SITS FLUSH TO FACE
.406 MIN 10.31 MIN
ENSURE EDGE OF BOARD
DOES NOT INTERFERE WITH
MATING CONNECTOR
MATERIAL:
FINISH:
SEE NOTES
SEE NOTES
SURFACE AREA:
N/A
PROPRIETARY
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
.030
.010
.005
ANGULAR: X
X X'
1 0'
15'
SV Microwave, Inc.
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
FSG 08/16/11
CHECKED:
APPROVED:
STW 08/16/11
STW 08/16/11
TITLE:
SMP FD MALE 2PORT PCB EDGE
MOUNT
SIZE CAGE CODE DWG. NO.
9311-60035
B 95077
SCALE: 16:1
SHEET 2 OF 2
很抱歉,暂时无法提供与“9311-60033”相匹配的价格&库存,您可以联系我们找货
