Type N Bulkhead Jack Crimp Style for RG-58, 142, 213, 214
and LMR-400 Flexible Cable
1. Identify connector parts. (6 piece parts)
2. Strip cable to dimensions shown. Do not nick
center conductor. A wire stripper of correct size is
recommended for this step. Tin center conductor
if contact will be solder attached. Do not tin center
conductor if contact will be crimp attached. Slide crimp
sleeve onto jacket of cable.
3. Assemble jack contact onto cable as shown. Jack
contact should butt against cable dielectric during
attachment. Solder Attachment: Solder jack contact
to center conductor through solder hole using .020
(.051) diameter flux core solder wire. Use a minimum
amount of solder for a good joint. Crimp Attachment:
Crimp jack contact to center conductor using Johnson
ergonomic hand crimp frame 140-0000-967 with
recommended hex size die set. Crimp location should
be on end of jack contact next to cable dielectric.
Crimp attachment to solid center conductor cables is
not recommended.
4. Flare braid and slide bulkhead jack connector
assembly over jack contact and under braid. Seat
bulkhead jack connector assembly firmly onto contact.
Arrange braid uniformly around crimp stem. Slide crimp
sleeve forward and crimp using Johnson ergonomic
hand crimp frame 140-0000-967 with recommended
hex size die set. Maintain forward pressure on cable
while crimping.
Part No.
“A”
“B”
Crimp
Sleeve “C”
Contact
Hex Size
Hex Size
RG-58/U, 141, 303
138-4307-407
.310 (7.87)
.389 (9.88)
.135 (3.43)
.213 (5.41)
.068 (1.73)
RG-55/U, 142, 223, 400
138-4308-407
.310 (7.87)
.389 (9.88)
.135 (3.43)
.213 (5.41)
.068 (1.73)
RG-8, 213
138-4316-407
.385 (9.78)
.400 (10.16)
.165 (4.19)
.429 (10.90)
.111 (2.82)
RG-9, 214
138-4318-407
.385 (9.78)
.400 (10.16)
.165 (4.19)
.429 (10.90)
.111 (2.82)
Cable Group
Assembly
Tool
138-4307/4308-407
138-4316/4318/4349-407
Crimp Frame
140-0000-967
140-0000-967
Die Set
140-0000-990
140-0000-991
271
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“138-4349-407”相匹配的价格&库存,您可以联系我们找货
