ROHS COMPLIANT
REVISION HISTORY
DESCRIPTION
REV
PRODUCT DATA DRAWING
DATE
APPROVED
A
DCN 41727
10/15
DAL
B
DCN 47253
03/18
STW
.405 10.29
.009±.003 0.23±0.08
.183 4.64
BACK END SOCKET CONTACT
ACCEPTS Ø.008 PIN
MATERIAL:
1/4-36 UNS-2A
M7 X .75-6g
BODY & INSERT:
STAINLESS STEEL PER AMS-5640,
ALLOY UNS S30300, TYPE 1
CONTACT:
BERYLLIUM COPPER PER ASTM B196,
ALLOY No. UNS C17300, TD04
BEAD:
ULTEM 1000 PER ASTM D5205
FINISH:
BODY:
PASSIVATED PER AMS-2700
INSERT:
GOLD PER ASTM B 488, TYPE I,
CODE C, CLASS 1.52, OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00005" MIN.
CONTACT:
GOLD PER ASTM B488, TYPE I,
CODE C, CLASS .50, OVER NICKEL
MATERIAL:
FINISH:
SEE NOTES
SEE NOTES
SURFACE AREA:
PERFORMANCE:
N/A
PROPRIETARY
IMPEDANCE:
FREQ. RANGE:
50 OHMS
DC TO 50.0 GHz
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
STW 06/14/01
CHECKED:
APPROVED:
STW 06/14/01
STW 06/14/01
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
2.4mm SPARK PLUG,
ACCEPTS Ø.008 PIN
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 12:1
SF1675-6004
SHEET 1 OF 1
很抱歉,暂时无法提供与“SF1675-6004”相匹配的价格&库存,您可以联系我们找货
