SF1521-60025
SF1521-60025
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONN2.92MMJCKSTR50OHMSOLDER
SF1521-60025 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING DATE APPROVED B DCN 49585 01/20 DAL C DCN 50234 10/20 BNK .438 11.13 FLATS .6325 16.07 .312 7.92 HEX .415 10.54 .495 12.57 .250 ACROSS FLATS 1/4-36 UNS-2A MATERIAL: BODY, SLEEVE, HEX NUT & CLAMP NUT: LOCK WASHER: CONTACT & FERRULE: STAINLESS STEEL PER AMS 5640, ALLOY No. UNS S30300, TYPE 1, OR ASTM A582, TYPE 303, CONDITION A. .093 MAX 2.36 MAX PANEL 300 SERIES STAINLESS STEEL BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 BEAD: POLYETHERIMIDE(ULTEM 1000) PER ASTM D5205 O-RING: SILICONE RUBBER PER A-A-59588, CLASS 2B, GRADE 50/60 .250 MIN 6.35 MIN FINISH: BODY, SLEEVE, HEX NUT, LOCK WASHER & CLAMP NUT: CONTACT & FERRULE: .235 MIN 5.97 MIN PASSIVATED PER AMS 2700. RECOMMENDED MOUNTING HOLE GOLD PER ASTM B 488, TYPE II, CODE C, CLASS .76, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. MATERIAL: FINISH: PERFORMANCE: IMPEDANCE: FREQ. RANGE: VSWR: SEE NOTES SEE NOTES SURFACE AREA: 50 OHMS DC TO 40.0 GHz. 1.25:1, DC TO 40.0 GHz. N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: FED 07/27/12 CHECKED: APPROVED: STW 08/22/12 STW 08/22/12 www.svmicrowave.com TITLE: SVK ST. BULKHEAD JACK FOR RG-405 CABLE SIZE DWG. NO. B SCALE: 7:1 SF1521-60025 SHEET 1 OF 1
SF1521-60025 价格&库存
很抱歉,暂时无法提供与“SF1521-60025”相匹配的价格&库存,您可以联系我们找货
