3811-40001
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPSPLUGSTR50OHMSOLDER
3811-40001 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING DATE APPROVED - REL. NRN 35514 09/17/09 STW A REV. DCN 37481 04/19/10 PJS B DCN 39509 11/12 STW .252 6.40 SMPS MALE INTERFACE FULL DETENT .104 2.64 REVISION HISTORY DESCRIPTION REV .090 2.29 .077 1.96 .158 4.01 TO CABLE STOP .049 1.24 RP MATERIAL: BODY & CONTACT: INSULATOR: FINISH: BODY & CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B GOLD PER ASTM B 488, TYPE II, CODE C, CLASS 1.27; OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: VSWR: 50 OHMS 1.20:1 DC TO 40.0 GHz TYPICAL 1.30:1 TO 65.0GHz TYPICAL INSERTION LOSS: .12 X SQRT(F(F IN GHz)) DWV: 250 VRMS OPERATING TEMP.: -55 C TO +125 C ENGAGEMENT: DISENGAGEMENT: 3.5 LBS TYPICAL 2.0 LBS TYPICAL MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: JMC 08/11/09 CHECKED: APPROVED: STW 09/17/09 STW 09/17/09 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPS MALE FULL DETENT FOR .047 SEMI-RIGID CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 20:1 3811-40001 SHEET 1 OF 1
3811-40001 价格&库存
很抱歉,暂时无法提供与“3811-40001”相匹配的价格&库存,您可以联系我们找货
