SF2912-60955
SF2912-60955
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMAPLUGR/A50OHMSOLDER
SF2912-60955 数据手册
PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV DATE APPROVED - REL. DCN 40084 09/27/13 STW A DCN 41319 05/15 STW .552 14.02 .312 7.92 .312 7.92 HEX RP .470 11.94 .240 6.10 MATERIAL: BODIES, FERRULE & COUPLING NUT: LOCK RING & CONTACT: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B SPACER: PCTFE PER ASTM D 1430 GASKET: SILICONE RUBBER PER A-A-59588, CLASS 2B, GRADE 50/60 FINISH: BODIES & COUPLING NUT: CONTACT & FERRULE: PASSIVATED PER AMS-2700. GOLD PER ASTM B 488, TYPE II, CODE C, 0.76 MIN., OVER ELECTROLESS NICKEL PER SAE-AMS-C-26074, CLASS 1, .00005" MIN. MATERIAL: FINISH: PERFORMANCE: SEE NOTES SEE NOTES SURFACE AREA: IMPEDANCE: FREQ. RANGE: VSWR: 50 OHMS DC TO 18.0 GHz 1.30: 1 DC TO 18 GHz N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: JMC 09/27/13 CHECKED: APPROVED: STW 09/27/13 STW 09/27/13 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMA R/A PLUG FOR Ø.047 CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 5:1 SF2912-60955 SHEET 1 OF 1
SF2912-60955 价格&库存
很抱歉,暂时无法提供与“SF2912-60955”相匹配的价格&库存,您可以联系我们找货
