ROHS COMPLIANT
PRODUCT DATA DRAWING
REVISION HISTORY
DESCRIPTION
REV
B
DCN 40542
DATE
APPROVED
04/14
FSG
.558 14.17
.312 7.92 HEX.
.433 11
.448 11.38
MATERIAL:
BODY,
FERRULE &
COUPLING NUT:
LOCK RING &
CONTACT:
STAINLESS STEEL PER AMS-5640,
ALLOY UNS S30300, TYPE 1
BERYLLIUM COPPER PER ASTM B196,
ALLOY No. UNS C17300, TD04
INSULATORS:
PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B
GASKET:
SILICONE RUBBER PER A-A-59588,
CLASS 2B, GRADE 50/60
FINISH:
BODY &
COUPLING NUT:
CONTACT &
FERRULE:
PASSIVATED PER AMS-2700.
GOLD PER ASTM B488, TYPE II,
CODE C, CLASS 0.76, OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00005" MIN.
MATERIAL:
FINISH:
PERFORMANCE:
SEE NOTES
SEE NOTES
SURFACE AREA:
IMPEDANCE:
FREQ. RANGE:
VSWR:
50 OHMS
DC TO 18.0 GHz
1.30:1 DC TO 18.0 GHz
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
NPD 12/01/80
CHECKED:
APPROVED:
RD 12/03/80
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
SMA R/A PLUG FOR
.086 S.R. CABLE
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 4:1
SF2915-6605
SHEET 1 OF 1
很抱歉,暂时无法提供与“SF2915-6605”相匹配的价格&库存,您可以联系我们找货
