SF4501-6039
SF4501-6039
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNPTNCPLUGSTR50OHMSOLDER
SF4501-6039 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING C DCN 41832 DATE APPROVED 11/15 DAL .770±.030 19.56±0.76 .562 14.27 HEX .558 14.17 .180 4.57 3X MATERIAL: BODY & COUPLING NUT: .040±.002 1.02±0.05 LOCK WIRE HOLES .375 ACROSS FLATS STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 LOCK RING: PHOSPHOR BRONZE PER ASTM B159, ALLOY 51000, TEMP. H08 INSULATORS: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B GASKET: SILICONE RUBBER PER A-A-59588, CLASS 2B, GRADE 50/60 FINISH: COUPLING NUT: BODY & CONTACT: PASSIVATED PER AMS-2700 GOLD PER ASTM B488, TYPE II, CODE C, CLASS .76, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: PERFORMANCE: N/A PROPRIETARY IMPEDANCE: FREQ. RANGE: 50 OHMS DC TO 15.0 GHz THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: BNK 11/12/15 CHECKED: APPROVED: DAL 11/12/15 DGG 11/04/81 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: PTNC PLUG SOLDER-ON FOR .141 S.R CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 4:1 SF4501-6039 SHEET 1 OF 1
SF4501-6039 价格&库存
很抱歉,暂时无法提供与“SF4501-6039”相匹配的价格&库存,您可以联系我们找货
