PRODUCT DATA DRAWING
ROHS COMPLIANT
REVISION HISTORY
DESCRIPTION
DATE
APPROVED
DCN 38515
09/11
STW
A
REV. DCN 39575
12/13/12
DAL
B
DCN 42425
06/16
STW
REV
.090 2.29
.008 0.20
4X .025 0.64
SLOTS
.095 2.41
.009 0.23
.065 1.65
RP
.041 1.04
.110 2.79
MATERIAL:
4X .025 0.64
BODY:
STAINLESS STEEL PER AMS-5640,
ALLOY UNS S30300, TYPE 1
PIN:
KOVAR PER ASTM-F15
GLASS:
CORNING 7070 OR EQUIVALENT
.010 0.25
.065 1.65
RECOMMENDED PCB LAYOUT
FINISH:
BODY & PIN:
MATERIAL:
PERFORMANCE:
IMPEDANCE:
OPERATING TEMP.:
SV P/N
3811-60005
3811-60006
GOLD PER ASTM B488, TYPE II,
CODE C, CLASS 1.27, OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00005" MIN.
50 OHMS.
-55 C TO +125 C.
NOTES:
1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE
CONTACT US AT applications@svmicro.com
FINISH:
SEE NOTES
SEE NOTES
SURFACE AREA:
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
FED 09/01/11
CHECKED:
APPROVED:
STW 09/01/11
STW 09/01/11
INTERFACE
SMOOTH BORE
FULL DETENT
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
SMPS MALE
SURFACE MOUNT
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 30:1
3811-60005-60006
SHEET 1 OF 1
很抱歉,暂时无法提供与“3811-60006”相匹配的价格&库存,您可以联系我们找货
