8921-60030
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNBMZJACKSTR50OHMPCB
8921-60030 数据手册
PRODUCT DATA DRAWING ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV - DCN 43137 DATE APPROVED 02/17 MAL .643 16.33 4X .155 3.94 .240 6.10 .036±.001 0.91±0.03 .250±.002 6.35±0.05 .312 7.92 .040 1.02 4X MATERIAL: BODY: STAINLESS STEEL (BAR STOCK) PER AMS 5640, ALLOY UNS S30300 CONTACT : BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B O-RING: SILICONE RUBBER PER A-A-59588, CLASS 2B, GRADE 60 FINISH: BODY, CONTACT & CONTACT SLEEVE: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27 OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com PERFORMANCE: IMPEDANCE: FREQ. RANGE: DWV: 50 OHMS DC TO 22.0 GHz 1000 VRMS MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 .030 .010 .005 ANGULAR: X X X' 1 0' 15' INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: VB 02/24/17 CHECKED: APPROVED: MAL 02/24/17 MAL 02/24/17 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: BMZ MALE BOARD MOUNT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 8:1 8921-60030 SHEET 1 OF 1
8921-60030 价格&库存
很抱歉,暂时无法提供与“8921-60030”相匹配的价格&库存,您可以联系我们找货
