ROHS COMPLIANT
REVISION HISTORY
DESCRIPTION
DATE
APPROVED
DCN 35555
12/07
STW
A
DCN 38375
07/11
STW
REV
PRODUCT DATA DRAWING
.180 4.57
.030 0.76
.015 0.38
.164 4.17
.098 2.49
.070±.001 1.78±0.03
RP
MATERIAL:
BODY&
PIN:
KOVAR PER ASTM F15
GLASS:
7070
FINISH:
BODY &
PIN:
GOLD PER ASTM B 488, TYPE II,
CODE C, CLASS 1.27; OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00005" MIN.
PERFORMANCE:
IMPEDANCE:
FREQ. RANGE:
VSWR:
DWV:
OPERATING TEMP.:
INSUL. RES.:
50 OHMS
DC TO 26.5 GHz
1.25:1 DC TO 18.0 GHz
1.35:1 DC TO 26.5 GHz
500 VRMS
-55 C TO +165 C
5000 MEGOHMS
MATERIAL:
FINISH:
SEE NOTES
SEE NOTES
SURFACE AREA:
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
HLP 12/03/07
CHECKED:
APPROVED:
STW 12/03/07
STW 12/03/07
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
SIZE
B
SMP MALE HERMETIC
SHROUD FULL DETENT
CAGE CODE DWG. NO.
1211-6041
95077
SCALE: 16:1
SHEET 1 OF 1
很抱歉,暂时无法提供与“1211-6041”相匹配的价格&库存,您可以联系我们找货
