1211-6043
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPPLUGSTR50OHMSOLDER
1211-6043 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION DATE APPROVED - DCN 37960 01/11 STW A DCN 38375 07/11 STW REV PRODUCT DATA DRAWING .030 0.76 .180 4.57 .015±.001 0.38±0.03 .164 4.17 .098 2.49 .070±.001 1.78±0.03 RP MATERIAL: BODY& PIN: KOVAR PER ASTM F15 GLASS: 7070 FINISH: BODY & PIN: GOLD PER ASTM B 488, TYPE II, CODE C, CLASS 1.27; OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: VSWR: DWV: OPERATING TEMP.: INSUL. RES.: 50 OHMS DC TO 26.5 GHz 1.25:1 DC TO 18.0 GHz 1.35:1 DC TO 26.5 GHz 500 VRMS -55 C TO +165 C 5000 MEGOHMS MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: FED 01/18/11 CHECKED: APPROVED: STW 01/18/11 STW 01/18/11 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMP MALE SB HERMETIC SHROUD SIZE CAGE CODE DWG. NO. B 95077 SCALE: 16:1 1211-6043 SHEET 1 OF 1
1211-6043 价格&库存
很抱歉,暂时无法提供与“1211-6043”相匹配的价格&库存,您可以联系我们找货
