ROHS COMPLIANT
PRODUCT DATA DRAWING
REVISION HISTORY
DESCRIPTION
REV
.125 3.18
DATE
APPROVED
DCN 39189
07/12
FSG
A
DCN 39367
09/12
STW
B
DCN 40225
12/13
FSG
2X .083 2.11
.131 3.33
2X
.012 0.29
4X .206 5.23
RP
4X .075 1.91
A
CONTACT FLUSH TO
.005 BELOW -A-
2X .048±.001 1.22±0.03
2X .113 2.87
4° B
2X .028 0.71
B
.020 0.51
2X
.057 1.45
.085 2.16
4X
MATERIAL:
BODY:
BRASS PER ASTM B16, ALLOY UNS No. C36000
INSULATOR:
TORLON 4203
FINISH:
.215 5.46
GOLD PER ASTM B488, TYPE II,
CODE C, CLASS 1.27, OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00005" MIN.
.255 6.48
NOTES:
1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE
CONTACT US AT applications@svmicro.com
MATERIAL:
FINISH:
SEE NOTES
SEE NOTES
SURFACE AREA:
PERFORMANCE:
IMPEDANCE:
.130 3.30
BERYLLIUM COPPER PER ASTM B196,
ALLOY No. UNS C17300, TD04
CONTACT:
BODY &
CONTACT:
.020 0.51
N/A
PROPRIETARY
50 OHMS
.125 3.18
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
FSG 07/05/12
CHECKED:
APPROVED:
FSG 07/05/12
FSG 07/05/12
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
2-PORT SMPM MALE FD
R/A CONTACT PCB MOUNT
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 12:1
3211-40024
SHEET 1 OF 1
很抱歉,暂时无法提供与“3211-40024”相匹配的价格&库存,您可以联系我们找货
