8821-60021
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNBZJACKSTR50OHMPCB
8821-60021 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING .382 9.70 - DCN 43165 DATE APPROVED 03/17 MAL .155 3.92 .040 1.02 4X .040 1.02 .248 6.30 2X .200 5.08 .051 1.28 .339 8.61 MATERIAL: BODY: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B FINISH: BODY& CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 0.76; OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .000050" MIN PERFORMANCE: IMPEDANCE: FREQ. RANGE: NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com MATERIAL: FINISH: 50 OHMS DC TO 2.0 GHz SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 .030 .010 .005 ANGULAR: X X X' 1 0' 15' INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: VB 03/03/17 CHECKED: APPROVED: MAL 03/03/17 MAL 03/03/17 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: BZ BOARD MOUNT JACK SIZE CAGE CODE DWG. NO. B 95077 SCALE: 4:1 8821-60021 SHEET 1 OF 1
8821-60021 价格&库存
很抱歉,暂时无法提供与“8821-60021”相匹配的价格&库存,您可以联系我们找货
