SF6545-6017
SF6545-6017
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNPNJACKSTR50OHMSOLDER
SF6545-6017 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV - .750 19.05 HEX. REL. DCN 40145 DATE APPROVED 10/24/13 STW 1.335 33.91 .530 MAX. 13.44 .884 22.45 .120 3.05 .875 22.23 .090±.001 2.29±0.03 5/8-24 UNEF-2A 9/16 HEX. O-RING MATERIAL: BODIE & HEX NUT: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 LOCKWASHER: 300 SERIES STAINLESS STEEL CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: REXOLITE PER LP-516 TYPE E2 O-RINGS: SILICONE RUBBER PER A-A-59588, CLASS 2B, GRADE 50/60 .532 13.51 MIN .630 16 MIN FINISH: BODIES, HEX NUT & LOCKWASHER: CONTACT: PASSIVATED PER AMS-2700. GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: RECOMMENDED MTG HOLE MATERIAL: FINISH: IMPEDANCE: FREQ. RANGE: 50 OHMS DC TO 18.0 GHz DISENGAGEMENT: 2 IN-LBS SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: JMC 10/24/13 CHECKED: APPROVED: STW 10/24/13 STW 10/24/13 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: PN BULKHEAD JACK FOR RG-405 CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 3:1 SF6545-6017 SHEET 1 OF 1
SF6545-6017 价格&库存
很抱歉,暂时无法提供与“SF6545-6017”相匹配的价格&库存,您可以联系我们找货
