MINI-UHF-16
MINI-UHF-16
    CINCH
    UHF, Mini Connector Plug, Male Pin Non-Constant Free Hanging (In-Line) Crimp or Solder
MINI-UHF-16 数据手册
INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST Mini-UHF Straight Crimp Type Plug Solder or Crimp Contact PART NUMBER MINI-UHF-16 CABLE TYPE PROFLEX RG-450 “A” .610 (15.49) CONTACT I.D. .055 (1.40) BODY I.D. .173 (4.39) FERRULE I.D. .261 (6.63) 1. Identify connector parts. (4 piece parts) 2. Slide heat shrink (as applicable) and crimp sleeve onto jacket of cable. Strip cable to dimensions shown. Do not nick braid or center conductor. Tin center conductor if contact will be solder attached. Do not tin center conductor if contact is to be crimp attached. A wire stripper of correct size is recommended for this step. 3. Assemble contact onto cable as shown. Solder Attachment: Solder contact to center conductor through hole using a minimum amount of solder for a good joint. Crimp Attachment (where applicable): Crimp contact to center conductor using recommended crimp tool. 4. Slide coupling nut onto the connector body. 5. Flare braid and slide body assembly over contact and under braid as shown. Then seat body assembly firmly onto contact until a gentle snap is felt, indicating the contact is in place. The cable may have to be held in a clamping fixture. Arrange braid uniformly around crimp stem. Slide crimp sleeve forward and crimp using recommended crimp tool. Slide heat shrink forward and shrink (as applicable). Contact I.D. Part Number Cable MINI-UHF-16 RG-450, Proflex .055 (1.40) Body I.D. Ferrule I.D. Crimp (Braid Hex) Contact Recommended Crimp Hex Crimp Tool 173 (4.40) .261 (6.63) .255 (6.48) .060 (1.52) 24-305P Cambridge Products, P.O. Box 1732, Waseca, MN 56093-0832 • 1-800-243-8814 • Fax: 507-833-6287 • www.cambridgeproducts.com Mini-UHF Connectors Specifications INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST Mini UHF connectors are low cost, general purpose units designed for low frequency system applications. These commercial quality connectors are equipped with threaded coupling interfaces for secure and reliable connections. The Standard UHF and Mini UHF connectors are not intermateable. Specifications* MINI UHF Electrical Characteristics Impedance: Nonconstant Frequency range: 0-2 GHz Working voltage: 500 volts RMS at sea level Dielectric withstanding voltage: 1500 volts RMS at sea level Insulation resistance: 5000 megohms minimum Environmental Characteristics Recommended temperature range: -55OC to +85OC Mechanical Characteristics Durability: 500 cycles Cable retention: 20 lbs., RG-58 C/U cable Materials Body and coupling nut: Zinc or brass Contact: Brass Crimp Sleeve: Brass Insulator: TPX Polymethylpetene Plating: Body - Nickel Crimp sleeve - Nickel Contact - Gold * These values are typical and may not apply to all connectors. Cambridge Products, P.O. Box 1732, Waseca, MN 56093-0832 • 1-800-243-8814 • Fax: 507-833-6287 • www.cambridgeproducts.com
MINI-UHF-16 价格&库存
很抱歉,暂时无法提供与“MINI-UHF-16”相匹配的价格&库存,您可以联系我们找货
