CONN005-R58
CONN005-R58
    LINXTECHNOLOGIES(灵思)
    CONN N JACK STR 50 OHM SOLDER
CONN005-R58 数据手册
Description Body Socket Insulation Crimp Ring O Ring Washer Nut Material Brass Brass PTFE Brass SI Rubber Brass Brass Finish Nickel Gold N/A Nickel Rubber Nickel Nickel REVISIONS CRIMP RING REV B DESCRIPTION Added New Title Block Ø0.252 (6.40) DATE APPV 12-JUL-12 SAH RECOMMENDED MOUNTING HOLE 0.500 (12.70) Ø0.634 (16.10) SOCKET SIDE VIEW 5/8-24UNEF-2A THREADS Ø0.862 (21.90) Ø0.531 (13.50) Ø0.177 (4.50) Ø0.083 (2.10) 0.673 (17.10) NUT Ø0.119 (3.02) 0.571 (14.50) WASHER H19 0.929 (23.60) FLAT 0.528 x2 (13.40) 5/8-24UNEF-2B THREADS Ø0.866 (22.00) 1.410 (35.70) RECOMMENDED CABLE STRIPPING DIMENSIONS 0.177 (4.50) 0.315 (8.00) 0.276 (7.00) RG-58 Cable CONN005-R58 ASSEMBLY INSTRUCTIONS 0.110 (2.80) 0.020 (0.50) NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 2. DIMENSIONS APPLY AFTER FINISHING. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: 1. Solder the socket to the center conductor. 2. Insert the socket, center conductor, and insulator into the body. 3. Wrap the braid around the tail of the body and crimp the ring with a FINISH: hex crimp tool labeled for use with RG-58 cable. PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 TITLE: MERLIN, OR 97532 N FEMALE BULKHEAD MOUNT CABLE END CRIMP FOR RG158 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 12-JUL-12 ENGR: S.HOGAN DT: 12-JUL-12 SCALE: 2:1 REV CONN005-R58 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONN005-R58 价格&库存
很抱歉,暂时无法提供与“CONN005-R58”相匹配的价格&库存,您可以联系我们找货
