SF1621-60003
SF1621-60003
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONN2.4MMJACK50OHMCOMPRESS
SF1621-60003 数据手册
2.4MM SERIES 2.4mm Interface at a Glance The 2.4mm connector was developed for use to 50 GHz. This connector series uses a thick outer wall to eliminate the fragility seen in SMA and 2.92mm connectors. The female socket is also strengthened to ensure reliable mating. The 2.4mm series mates with SMA, 3.5mm and 2.92mm connectors with adapters and can mate with the 1.85mm series without adapters. Electrical Specifications Impedance 50Ω Frequency 50 GHz VSWR 1.03 + .005 f .04 √ f Insertion Loss ≥ 100 dB Shielding Effectiveness 2.4MM SERIES Mechanical Specifications Mating Cycles 500 Recommended Torque 5 - 7 in - lbs Inter-mate ability 1.85mm Environmental Specifications Temperature Rating Corrosion (Salt Spray) Vibration Shock Thermal Shock Moisture Resistance Barometric Pressure (Altitude) -65°C to +165°C MIL-STD-202, Method 101, Condition B MIL-STD-202, Method 204, Condition D, 20 Gs MIL-STD-202, Method 213, Condition I, 100 Gs MIL-STD-202, Method 107. Cond. B, -65°C to +125°C MIL-STD-202, Method 106, Less Step 7B MIL-STD-202, Method 105, Condition C, 70k Ft. Note: Specifications, dimensions and images are typical for the series and may vary by part number www.svmicrowave.com | 561.840.1800 42 42 2.4MM SERIES Male Cable Connector .602 Cable P/N .047 SF1611-60001 .085 SF1611-60003 Female Cable Connector .794 M7 X .75-6g .250 HEX. Cable P/N .047 SF1621-60014 .085 SF1621-60009 Female Bulkhead Cable Connector .698 M7 X 75-6g 2X .312 HEX. Still looking? Contact us for access to over 10,000 products. 43 Cable P/N .047 SF1621-60005 .085 SF1644-6001 www.svmicrowave.com | 561.840.1800 2.4MM SERIES 2X .250 HEX. .312 HEX. 2.4MM SERIES Female Flange Mount Connector, 2 Hole (Accepts Ø.012” Pin) .441 .222 M7 X .75-6g P/N SF1621-60017 2.4MM SERIES Female Flange Compression Mount Connector, 2 Hole .222 .440 DETAIL A .003 .008 A M7 X .75-6g P/N SF1621-60003 Contact SV directly to access our database of recommended PCB layouts Female Edge Launch Connector (.062” PCB Thickness) .500 .215 M7 X .75-6g P/N 1621-60008 Contact SV directly to access our database of recommended PCB layouts www.svmicrowave.com | 561.840.1800 44 2.4MM SERIES Male Sparkplug Connector (Accepts Ø.008” Pin) .405 .183 1/4-36 UNS-2A M7 X .75-6g P/N Feed-Thru Hermetic Seal A B C øE øD P/N A B C øD øE 066-15-000 .040" .055" .029" .076" .012" 066-15-001 .040" .055" .080" .076" .012" 066-15-002 .030" .055" .026" .068" .009" 066-15-003 .030" .055" .080" .068" .009" 066-15-004 .030" .055" .120" .068" .009" 066-15-005 .050" .060" .125" .158" .020" 2.4mm Male to Male Adapter .828 2X .312 HEX. P/N SF1116-6039 Still looking? Contact us for access to over 10,000 products. 45 www.svmicrowave.com | 561.840.1800 2.4MM SERIES SF1675-600 4 2.4MM SERIES 2.4mm Female to Female Adapter .815 2X M7 X .075-6g P/N SF1116-6053 2.4MM SERIES 2.4mm Male to Female Adapter .821 M7 X .075-6g .312 HEX. P/N SF1116-6040 2.4mm Male to 2.92mm Male Adapter .864 2X .312 HEX. P/N SF1116-6007 www.svmicrowave.com | 561.840.1800 46 2.4MM SERIES 2.4mm Male to 2.92mm Female Adapter .765 1/4-36 UNS-2A .312 HEX. P/N 2.4mm Female to 2.92mm Male Adapter .838 M7 X .075-6g .312 HEX. P/N SF1116-6003 2.4mm Female to 2.92mm Female Adapter .796 M7 X .75-6g 1/4-36 UNS-2A P/N SF1116-6004 Still looking? Contact us for access to over 10,000 products. 47 www.svmicrowave.com | 561.840.1800 2.4MM SERIES SF1116-6002 2.4MM SERIES Male Termination .422 .312 HEX. P/N SF8016-6304 2.4MM SERIES Female Termination .620 M7 X .75-6g P/N SF8016-6402 www.svmicrowave.com | 561.840.1800 48 2.4MM NOTES 2.4MM NOTES 49 www.svmicrowave.com | 561.840.1800
SF1621-60003 价格&库存
很抱歉,暂时无法提供与“SF1621-60003”相匹配的价格&库存,您可以联系我们找货
