EM257512VO
EM257512VO
    EATON(伊顿)
    TERM BLOCK HDR 12POS VERT 5.08MM
EM257512VO 数据手册
EM2575 Series EuroMag Terminal Blocks Header (Mates with EM2565, EM3108 Series); 5.08 Centers EM257512HC SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.20” (5.08mm) Consult factory for 0.40” (10.16mm) Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified 2 3 4 5 6 7 8 9 10 11 12 13 10.16 15.24 20.32 25.40 30.48 35.56 40.64 45.72 50.80 55.88 60.96 66.04 12.08 17.16 22.24 27.32 32.40 37.48 42.66 47.64 62.72 67.80 62.88 67.96 Poles Open L (mm) Closed L (mm) 14 15 16 17 18 19 20 21 22 23 24 71.12 76.20 81.28 86.36 91.44 96.52 101.60 106.68 111.76 116.84 121.92 73.04 78.12 83.20 88.28 93.36 98.44 103.52 105.60 113.68 118.76 123.84 EM257506VO Dimensions - mm (in) HORIZONTAL OPEN HORIZONTAL CLOSED L+ _0.5 L+ _0.5 12+ _0.3 (0.472") 8.3+ _0.3 (0.327") 1.8+ _0.3 (0.071") To convert to inches, divide by 25.4 1+ _0.1 (0.039") 1.00+ _0.1 (0.039") 5.08+ _0.1 (0.200") 5.08+ _0.1 (0.200") Ø1.5 (Ø 0.059") 12+ _0.3 (0.472") Closed L (mm) EM257512VC 4.5+ _0.3 (0.177") Poles Open L (mm) EM257506HO 1.8+ _0.3 (0.071") PCB Hole Layout 5.08+ _0.1 (0.200") VERTICAL CLOSED VERTICAL OPEN 12±0.3 (0.472") 5.08±0.1 (0.200") L±0.5 L±0.5 8.3±0.3 (0.327") 1±0.1 (0.039") 1.00±0.1 [0.039] 3.8±0.3 (0.150") 4.5±0.3 (0.177") Ø1.5 (Ø 0.059") 5.08±0.1 (0.200") 8.3±0.3 (0.327") PCB Hole Layout 3.8±0.3 (0.150") Plug & Header Compliance References Edge Connectors, One-Sided Boards EuroMag Series Terminal Blocks: Single Row EuroMag Series PCB Mount Pluggable Terminal Blocks Part Numbering System En Mn 2n 5n 7n 5 nn n Series # of Poles 02 to 24 n n H - horizontal V - vertical O - open C - closed Orientation Side Base Mating Plugs: EM2565 pg. 89 EM2488 pg. 90 EM3108 pg. 91 For additional product information, visit www.eaton.com/connectors 92
EM257512VO 价格&库存
很抱歉,暂时无法提供与“EM257512VO”相匹配的价格&库存,您可以联系我们找货
