P-100-50812
P-100-50812
    AMERICANELECTRICAL(美国电气)
    TERMBLOCKPLUG12POSSTR5.08MM
P-100-50812 数据手册
Printed Circuit Board Terminal Blocks & Connectors AEI offers single and dual level terminal blocks for printed circuit boards on 3.5mm, 5.0mm, .08mm, 7.5mm and 7.62mm in modular 2 or 3 pole designs. Connectors are offered from 3.50mm, 3.81mm, 5.00mm and 5.08mm versions in 90° and 180° configuration up to 24 poles. 274 Printed Circuit Board terminal blocks Single Level • 90° • Pitch: 3.50 mm Technical Terminal: Wire protector: Insulating Body: Screw: Color: Operation temperature: Short-time Temperature: Current rating: Insulation withstanding volt: Insulation resistance: PCB hole Diameter: Wire strip length: Wire range: Screws torque: Brass, Tin plated Stainless strip steel Polyester M2.0, steel, Chromatized Black -33°C to +105°C Up to 200°C (+392°F) 6 amp AC300V AC1500V min >5000Ω at DC500V ϕ 1.4 mm 4mm - 5mm 16 - 26 AWG 2.5 lb-inch Item No. Poles A (mm) 2 3 7.00 10.50 T-212-350M2 T-212-350M3 A (inch) 0.276 0.413 Single Level • 90° • Pitch: 5.00 mm Technical Cage clamp: Terminal: Insulating Body: Screw: Color: Operation temperature: Short-time Temperature: Current rating: Insulation withstanding volt: Insulation resistance: PCB hole Diameter: Wire strip length: Wire range: Screws torque: Brass, Ni plated Brass, Tin plated, 0.8t Polyamide66 (UL94V-0) M2.6, steel, Ni plated Green -55°C to +105°C Up to 250°C (+482°F) 16 amp AC300V AC2000V min >5000Ω at DC500V ϕ 1.4 mm - ϕ 1.5 mm 4mm - 5mm 14 - 24 AWG 5.0 lb-inch Item No. Poles A (mm) 2 3 10.00 15.00 T-312-500M2 T-312-500M3 A (inch) 0.394 0.591 Single Level • 90° • Pitch: 5.08 mm Technical Terminal: Wire protector: Insulating Body: Screw: Color: Operation temperature: Short-time Temperature: Current rating: Insulation withstanding volt: Insulation resistance: PCB hole Diameter: Wire strip length: Wire range: Screws torque: Brass, Ni plated Brass, Tin plated, 0.8t Polyamide66 (UL94V-0) M2.6, steel, Ni plated Green -55°C to +105°C Up to 250°C (+482°F) 16 amp AC300V AC2000V min >5000Ω at DC500V ϕ 1.4 mm - ϕ 1.5 mm 4mm - 5mm 14 - 24 AWG 5.0 lb-inch Item No. Poles A (mm) 2 3 10.16 15.24 T-312-508M2 T-312-508M3 A (inch) 0.400 0.600 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 275 Printed Circuit Board terminal blocks Single Level • 90° • Pitch: 7.50 mm Technical Cage clamp: Terminal: Insulating Body: Screw: Color: Operation temperature: Short-time Temperature: Current rating: Insulation withstanding volt: Insulation resistance: PCB hole Diameter: Wire strip length: Wire range: Screws torque: Brass, Ni plated Brass, Tin plated, 0.8t Polyamide66 (UL94V-0) M2.6, steel, Ni plated Green -55°C to +105°C Up to 250°C (+482°F) 16 amp AC300V AC2000V min >5000Ω at DC500V ϕ 1.4 mm - ϕ 1.5 mm 4mm - 5mm 14 - 24 AWG 5.0 lb-inch Item No. Poles A (mm) 2 3 15.00 22.50 T-312-750M2 T-312-750M3 A (inch) 0.591 0.886 Single Level • 90° • Pitch: 7.62 mm Technical Cage clamp: Terminal: Insulating Body: Screw: Color: Operation temperature: Short-time Temperature: Current rating: Insulation withstanding volt: Insulation resistance: PCB hole Diameter: Wire strip length: Wire range: Screws torque: Brass, Ni plated Brass, Tin plated, 0.8t Polyamide66 (UL94V-0) M2.6, steel, Ni plated Green -55°C to +105°C Up to 250°C (+482°F) 16 amp AC300V AC2000V min >5000Ω at DC500V ϕ 1.4 mm - ϕ 1.5 mm 4mm - 5mm 14 - 24 AWG 5.0 lb-inch Item No. Poles A (mm) 2 3 15.24 22.86 T-312-762M2 T-312-762M3 A (inch) 0.600 0.900 Single Level • 90° • Pitch: 3.81 mm Technical Cage clamp: Terminal: Insulating Body: Screw: Color: Operation temperature: Short-time Temperature: Current rating: Insulation withstanding volt: Insulation resistance: PCB hole Diameter: Wire strip length: Wire range: Screws torque: Brass, Ni plated Brass, Tin plated, 0.5t Polyamide66 (UL94V-0) M2.0, steel, Ni plated Green -55°C to +105°C Up to 200°C (+392°F) 8 amp AC300V AC2000V min >5000Ω at DC500V ϕ 1.3 4mm - 5mm 16 - 26 AWG 2.5 lb-inch Item No. Poles A (mm) 2 3 7.62 11.43 T-332-381M2 T-332-381M3 276 A (inch) 0.300 0.450 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Printed Circuit Board terminal blocks Double Level • 90° • Pitch: 5.00 mm Technical Cage clamp: Terminal: Insulating Screw: Color: Operation temperature: Short-time Temperature: Current rating: Insulation withstanding volt: Insulation resistance: PCB hole Diameter: Wire strip length: Wire range: Screws torque: Brass, Ni plated Brass, Tin plated, 0.8t Body: Polyamide66 (UL94V-0) M2.6, steel, Ni plated Green -55°C to +105°C Up to 250°C (+482°F) 16 amp AC300V AC2000V min >5000Ω at DC500V ϕ 1.4 mm - ϕ 1.5 mm 4mm - 5mm 14 - 24 AWG 4.5 lb-inch Item No. Poles A (mm) 2 3 12.50 17.50 T-362-500M2 T-362-500M3 A (inch) 0.492 0.689 Double Level • 90° • Pitch: 5.08 mm Technical Cage clamp: Terminal: Insulating Body: Screw: Color: Operation temperature: Short-time Temperature: Current rating: Insulation withstanding volt: Insulation resistance: PCB hole Diameter: Wire strip length: Wire range: Screws torque: Brass, Ni plated Brass, Tin plated, 0.8t Polyamide66 (UL94V-0) M2.6, steel, Ni plated Green -55°C to +105°C Up to 250°C (+482°F) 16 amp AC300V AC2000V min >5000Ω at DC500V ϕ 1.4 mm - ϕ 1.5 mm 4mm - 5mm 14 - 24 AWG 4.5 lb-inch Item No. Poles A (mm) 2 3 12.70 17.78 T-362-508M2 T-362-508M3 A (inch) 0.500 0.700 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 277 Printed Circuit Board Plugs Plugs • 180° Technical Cage clamp: Contact: Insulating Body: Screw: Color: Operation temperature: Short-time temperature: Current rating: Insulation withstanding volt: Insulation resistance: Wire strip length: Wire range: Screws torque: Brass, Ni plated Phosphor bronze, Tin plated, 0.4t Polyamide66 (UL94V-0) M3.0, steel, Zinc plated Green -55°C to +105°C Up to 250°C (+482°F) 16 amp AC300V AC2000V min >5000Ω at DC500V 4 mm - 5 mm 14 - 24 AWG 4.5 lb-inch Pitch: 5.00 mm Item No. P-100-50002 P-100-50003 P-100-50004 P-100-50005 P-100-50006 P-100-50007 P-100-50008 Poles A (mm) A (inch) 2 3 4 5 6 7 8 10.00 15.00 20.00 25.00 30.00 35.00 40.00 0.394 0.591 0.787 0.984 1.181 1.378 1.575 Item No. Poles A (mm) A (inch) P-100-50009 P-100-50010 P-100-50011 P-100-50012 9 10 11 12 P-100-50024 24 45.00 50.00 55.00 60.00 120.00 1.772 1.969 2.165 2.362 4.724 Pitch: 5.08 mm Item No. P-100-50802 P-100-50803 P-100-50804 P-100-50805 P-100-50806 P-100-50807 P-100-50808 Poles A (mm) A (inch) 2 3 4 5 6 7 8 10.16 15.24 20.32 25.40 30.48 35.56 40.64 0.400 0.600 0.800 1.000 1.200 1.400 1.600 Item No. P-100-50809 P-100-50810 P-100-50811 P-100-50812 Poles A (mm) A (inch) 9 10 11 12 P-100-50824 24 45.72 50.80 55.88 60.96 121.92 1.800 2.000 2.200 2.400 4.800 Plugs • 90° • Pitch: 5.00 mm Technical Cage clamp: Brass, Ni plated Contact: Phosphor bronze, Tin plated, 0.4t Insulating Body: Polyamide66 (UL94V-0) Screw: M2.6, steel, Zinc plated Color: Green Operation temperature: -55°C to +105°C Short-time temperature: Up to 250°C (+482°F) Current rating: 16 amp AC300V Insulation withstanding volt: AC2000V min Insulation resistance: >5000Ω at DC500V Wire strip length: 7 mm Wire range: 14 - 24 AWG Screws torque: 4.5 lb-inch Item No. P-200-50002 P-200-50003 P-200-50004 P-200-50005 P-200-50006 P-200-50007 P-200-50008 278 Poles A (mm) A (inch) 2 3 4 5 6 7 8 10.00 15.00 20.00 25.00 30.00 35.00 40.00 0.394 0.591 0.787 0.984 1.181 1.378 1.575 Item No. P-200-50009 P-200-50010 P-200-50011 P-200-50012 Poles A (mm) A (inch) 9 10 11 12 P-200-50024 24 45.00 50.00 55.00 60.00 120.00 1.772 1.969 2.165 2.362 4.724 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Printed Circuit Board Plugs Plugs • 180° • Pitch: 3.50 mm Technical Cage clamp: Contact: Insulating Body: Screw: Color: Operation temperature: Short-time temperature: Current rating: Insulation withstanding volt: Insulation resistance: Wire strip length: Wire range: 16 - 26 AWG Screws torque: 2.5 lb-inch Item No. P-420-35002 P-420-35003 P-420-35004 P-420-35005 P-420-35006 P-420-35007 P-420-35008 Brass, Ni plated Phosphor bronze, Tin plated, 0.3t Polyamide66 (UL94V-0) M2.0, steel, Zinc Green -55°C to +105°C Up to 250°C (+482°F) 10 amp AC300V AC2000V min >5000Ω at DC500V 6.5 mm Poles A (mm) A (inch) 2 3 4 5 6 7 8 7.80 11.30 14.80 18.30 21.80 25.30 28.80 0.307 0.445 0.583 0.720 0.858 0.996 1.134 Item No. P-420-35009 P-420-35010 P-420-35011 P-420-35012 P-420-35013 P-420-35014 Poles A (mm) A (inch) 9 10 11 12 13 14 32.30 35.80 39.30 42.80 46.30 49.80 1.272 1.409 1.547 1.685 1.823 1.961 Plugs • 180° • Pitch: 3.81 mm Technical Cage clamp: Contact: Insulating Body: Screw: Color: Operation temperature: Short-time temperature: Current rating: Insulation withstanding volt: Insulation resistance: Wire strip length: Wire range: Screws torque: Item No. P-420-38102 P-420-38103 P-420-38104 P-420-38105 P-420-38106 P-420-38107 P-420-38108 Brass, Ni plated Phosphor bronze, Tin plated, 0.3t Polyamide66 (UL94V-0) M2.0, steel, Zinc Green -55°C to +105°C Up to 250°C (+482°F) 10 amp AC300V AC2000V min >5000Ω at DC500V 6.5 mm 16 - 26 AWG 2.5 lb-inch Poles A (mm) A (inch) 2 3 4 5 6 7 8 8.41 12.22 16.03 19.84 23.65 27.46 31.27 0.331 0.481 0.631 0.781 0.931 1.081 1.231 Item No. P-420-38109 P-420-38110 P-420-38111 P-420-38112 Poles A (mm) A (inch) 9 10 11 12 35.08 38.89 42.70 46.51 1.381 1.531 1.681 1.831 P-420-38116 16 61.75 2.431 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 279 Printed Circuit Board Headers Headers • Closed 90° • Pitch: 3.50 mm Technical Solder pin: Insulating Body: Color: Operation temperature: Short-time temperature: Current rating: Insulation withstanding volt: Insulation resistance: PDB hole Diameter: Item No. 0.8 mm, Brass, Tin plated Polyamide66 (UL94V-0) Green -55°C to +105°C Up to 250°C (+482°F) 12 amp AC300V AC2000V min >5000Ω at DC500V ϕ 1.3 mm Poles A (mm) A (inch) H-030-35002 H-030-35003 H-030-35004 H-030-35005 H-030-35006 H-030-35007 H-030-35008 2 3 4 5 6 7 8 7.60 11.10 14.60 18.10 21.60 25.10 28.60 0.299 0.437 0.575 0.713 0.850 0.988 1.126 Item No. Poles A (mm) A (inch) H-030-35009 H-030-35010 H-030-35011 H-030-35012 H-030-35013 H-030-35014 9 10 11 12 13 14 32.10 35.60 39.10 42.60 46.10 49.60 1.264 1.402 1.539 1.677 1.815 1.953 Headers • Closed 90° • Pitch: 3.81 mm Technical Solder pin: Insulating Body: Color: Operation temperature: Short-time temperature: Current rating: Insulation withstanding volt: Insulation resistance: PDB hole Diameter: Item No. H-030-38102 H-030-38103 H-030-38104 H-030-38105 H-030-38106 H-030-38107 H-030-38108 280 0.8 mm, Brass, Tin plated Polyamide66 (UL94V-0) Green -55°C to +105°C Up to 250°C (+482°F) 12 amp AC300V AC2000V min >5000Ω at DC500V ϕ 1.3 mm Poles A (mm) A (inch) 2 3 4 5 6 7 8 8.23 12.04 15.85 19.66 23.47 27.28 31.09 0.324 0.474 0.624 0.774 0.924 1.074 1.224 Item No. Poles A (mm) A (inch) H-030-38109 H-030-38110 H-030-38111 H-030-38112 9 10 11 12 34.90 38.71 42.52 46.33 1.374 1.524 1.674 1.824 H-030-38116 16 61.57 2.424 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Printed Circuit Board Headers Headers • Closed 90° • Pitch: 5.00 mm Technical Solder pin: Insulating Body: Color: Operation temperature: Short-time temperature: Current rating: Insulation withstanding volt: Insulation resistance: PDB hole Diameter: Item No. H-030-50002 H-030-50003 H-030-50004 H-030-50005 H-030-50006 H-030-50007 H-030-50008 1.0 mm, Brass, Tin plated Polyamide66 (UL94V-0) Green -55°C to +105°C Up to 250°C (+482°F) 12 amp AC300V AC2000V min >5000Ω at DC500V ϕ 1.5 mm Poles A (mm) A (inch) 2 3 4 5 6 7 8 11.60 16.60 21.60 26.60 31.60 36.60 41.60 0.457 0.654 0.850 1.047 1.244 1.441 1.638 Item No. Poles A (mm) A (inch) H-030-50009 H-030-50010 H-030-50011 H-030-50012 9 10 11 12 H-030-50016 16 46.60 51.60 56.60 61.60 121.60 1.835 2.031 2.228 2.425 4.787 Headers • Closed 90° • Pitch: 5.08 mm Technical Solder pin: Insulating Body: Color: Operation temperature: Short-time temperature: Current rating: Insulation withstanding volt: Insulation resistance: PDB hole Diameter: Item No. H-030-50802 H-030-50803 H-030-50804 H-030-50805 H-030-50806 H-030-50807 H-030-50808 1.0 mm, Brass, Tin plated Polyamide66 (UL94V-0) Green -55°C to +105°C Up to 250°C (+482°F) 12 amp AC300V AC2000V min >5000Ω at DC500V ϕ 1.5 mm Poles A (mm) A (inch) 2 3 4 5 6 7 8 11.76 16.84 21.92 27.00 32.08 37.16 42.24 0.463 0.663 0.863 1.063 1.263 1.463 1.663 Item No. Poles A (mm) A (inch) H-030-50809 H-030-50810 H-030-50811 H-030-50812 9 10 11 12 H-030-50816 16 47.32 52.40 57.48 62.56 123.52 1.863 2.063 2.263 2.463 4.863 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 281 Printed Circuit Board Headers Headers • Closed 180° • Pitch: 3.50 mm Technical Solder pin: Insulating Body: Color: Operation temperature: Short-time temperature: Current rating: Insulation withstanding volt: Insulation resistance: PDB hole Diameter: Item No. H-040-35002 H-040-35003 H-040-35004 H-040-35005 H-040-35006 H-040-35007 H-040-35008 0.8 mm, Brass, Tin plated Polyamide66 (UL94V-0) Green -55°C to +105°C Up to 250°C (+482°F) 12 amp AC300V AC2000V min >5000Ω at DC500V ϕ 1.3 mm Poles A (mm) A (inch) 2 3 4 5 6 7 8 7.60 11.10 14.60 18.10 21.60 25.10 28.60 0.299 0.437 0.575 0.713 0.850 0.988 1.126 Item No. Poles A (mm) A (inch) H-040-35009 H-040-35010 H-040-35011 H-040-35012 H-040-35013 H-040-35014 9 10 11 12 13 14 32.10 35.60 39.10 42.60 46.10 49.60 1.264 1.402 1.539 1.677 1.815 1.953 Headers • Closed 180° • Pitch: 3.81 mm Technical Solder pin: Insulating Body: Color: Operation temperature: Short-time temperature: Current rating: Insulation withstanding volt: Insulation resistance: PDB hole Diameter: Item No. H-040-38102 H-040-38103 H-040-38104 H-040-38105 H-040-38106 H-040-38107 H-040-38108 282 0.8 mm, Brass, Tin plated Polyamide66 (UL94V-0) Green -55°C to +105°C Up to 250°C (+482°F) 12 amp AC300V AC2000V min >5000Ω at DC500V ϕ 1.3 mm Poles A (mm) A (inch) 2 3 4 5 6 7 8 8.23 12.04 15.85 19.66 23.47 27.28 31.09 0.324 0.474 0.624 0.774 0.924 1.074 1.224 Item No. Poles A (mm) A (inch) H-040-38109 H-040-38110 H-040-38111 H-040-38112 9 10 11 12 34.90 38.71 42.52 46.33 1.374 1.524 1.674 1.824 H-040-38116 16 61.57 2.424 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com Printed Circuit Board Headers Headers • Closed 180° • Pitch: 5.00 mm Technical Solder pin: Insulating Body: Color: Operation temperature: Short-time temperature: Current rating: Insulation withstanding volt: Insulation resistance: PDB hole Diameter: Item No. H-040-50002 H-040-50003 H-040-50004 H-040-50005 H-040-50006 H-040-50007 H-040-50008 1.0 mm, Brass, Tin plated Polyamide66 (UL94V-0) Green -55°C to +105°C Up to 250°C (+482°F) 12 amp AC300V AC2000V min >5000Ω at DC500V ϕ 1.5 mm Poles A (mm) A (inch) 2 3 4 5 6 7 8 11.60 16.60 21.60 26.60 31.60 36.60 41.60 0.457 0.654 0.850 1.047 1.244 1.441 1.638 Item No. Poles A (mm) A (inch) H-040-50009 H-040-50010 H-040-50011 H-040-50012 9 10 11 12 H-040-50016 16 46.60 51.60 56.60 61.60 121.60 1.835 2.031 2.228 2.425 4.787 Headers • Closed 180° • Pitch: 5.08 mm Technical Solder pin: Insulating Body: Color: Operation temperature: Short-time temperature: Current rating: Insulation withstanding volt: Insulation resistance: PDB hole Diameter: Item No. H-040-50802 H-040-50803 H-040-50804 H-040-50805 H-040-50806 H-040-50807 H-040-50808 1.0 mm, Brass, Tin plated Polyamide66 (UL94V-0) Green -55°C to +105°C Up to 250°C (+482°F) 12 amp AC300V AC2000V min >5000Ω at DC500V ϕ 1.5 mm Poles A (mm) A (inch) 2 3 4 5 6 7 8 11.76 16.84 21.92 27.00 32.08 37.16 42.24 0.463 0.663 0.863 1.063 1.263 1.463 1.663 Item No. Poles A (mm) A (inch) H-040-50809 H-040-50810 H-040-50811 H-040-50812 9 10 11 12 H-040-50816 16 47.32 52.40 57.48 62.56 123.52 American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 1.863 2.063 2.263 2.463 4.863 283 Screwdrivers The ergonomic design of our screwdriver handles efficiently help to provide the proper tightening torque for your terminal block application. Insulation is rated at 10,000V for your safety. The tips of our screwdrivers are made of hardened steel for a longer tool life. 284 Screwdrivers for Terminal Blocks Features • • • • ergonomic handle provides proper tightening torque impact resistant material used to provide long lasting use insulation sleeve provides isolation up to 10,000 V Approvals: DIN - VDE 0680/2, ISO, IEC 900, EN 60900 W900837 W900832 W900838 W900833 W900844 W900839 W900834 W900840 W900836 W900841 W900858 W900857 A B C Description Part No. Insulated Screwdrivers W900837 0.4 W900838 0.5 W900839 0.6 W900840 0.8 W900841 1.0 KIT for Insulated Screwdrivers (3) W900844 Non-Insulated Screwdrivers W900832 0.5 W900833 0.6 W900834 0.8 KIT for Non-Insulated Screwdrivers (3) W900836 Insulated Phillips Screwdriver W900858 (100 mm) Non-Insulated Phillips Screwdriver W900857 (80 mm) A (mm) B (mm) 2.5 3.0 3.5 4.0 5.5 C (mm) 80 100 100 100 125 (includes one of each: W900838, W900839, W900840) 3.0 3.5 4.0 80 100 100 (includes one of each: W900832, W900833, W900834) American Electrical • 456 Southlake Blvd. • Richmond, VA 23236 • 804.379.2899 • fax: 804.379.8935 • www.americanelectrical.com 285
P-100-50812 价格&库存
很抱歉,暂时无法提供与“P-100-50812”相匹配的价格&库存,您可以联系我们找货
