ECG.0B.303.CLL
www.lemo.com
SUMMARY
# Wires
Low voltage
3
Image is for illustrative purpose only
Series
0B
Termination type
Female solder
IP rating
50
AWG wire size
28.00 - 20.00
Cable Ø
0.00 - 0.00 mm
Status
active
Matching parts
FGG.0B.303.CLAD52
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EC*: Fixed receptacle with two nuts (back panel mounting)
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
5.12 g
Performance
Configuration
0B.303 : 3 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
8 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.9 mm (0.035in)
Bucket Dia.: 1.0 mm (0.039in)
Max. Solid Conductor: 0.56 mm^2 (AWG 20)
Max. Stranded Conductor: 0.56 mm^2 (AWG 20)
R (max): 4.8 mOhm
Vtest (contact-shell): 900 V (AC), 1270 V (DC)
Vtest (contact-contact): 1200 V (AC), 1700 V (DC)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
B
E
L
M
N
S1
S3
e
mm.
12
12.4
5.5
20.7
2.5
19.1
8.2
11
M9x0.6
in.
0,47
0,49
0,22
0,81
0,10
0,75
0,32
0,43
RECOMMENDED BY LEMO
Tools
Spanner 2:
DCH.91.121.PA
Spanner wrench:
Socket for torque wrench DCM.65.100.AZ and DCM.0S.M09.4
2/3
Cables
CMN.03.T28.031PGCE
PVC
CMN.03.T28.031PGZE
CMN.03.T28.031PNCE
GREY
Grey
PVC
Black
130240
PVC
Black
130250
PVC
Grey
30110
PVC
Grey
30141
PVC
Grey
30260
PVC
Black
3041
PVC
Grey
3050
PVC
Black
3081
PVC
Black
3220
PVC
Black
3280
PVC
Black
60080
PVC
Grey
CMN.03.T28.031PNZE
3/3
很抱歉,暂时无法提供与“ECG.0B.303.CLL”相匹配的价格&库存,您可以联系我们找货
