HANDLE
AAAHZ SHOWN
FLEX
RELIEF
CONNECTOR
QT3FZ SHOWN
AAA3FZ
SHOWN
4 PIN
3 PIN
5 PIN
7 PIN
6 PIN
CONTACTS AS VIEWED FACING FEMALE CONECTOR
AAA
F
Z
2.97±0.12
F
75.4±3.05
SMALLER CABLES
SHORTEN ASSEMBLY
0.71
18.0
FLAT
SERIES:
Q-G CONNECTOR
# OF CONTACT SOCKETS:
3, 4, 5, 6 OR 7
0.65
16.4
FLAT
0.62
15.8
GENDER:
FEMALE
0.78
19.7
HANDLE STYLE:
BLANK - METAL HANDLE (SEE FINISH BELOW)
P - PLASTIC HANDLE, BLACK
FINISH:
BLANK - NICKEL HANDLE & CONNECTOR,
WITH BLACK FLEX RELIEF & GREEN INSERT
B - BLACK HANDLE & CONNECTOR,
WITH BLACK FLEX RELIEF & BLACK INSERT
W - WHITE HANDLE & NICKEL FINISH CONNECTOR
WITH WHITE FLEX RELIEF & GREEN INSERT
0.84
21.2
0.49
12.3
G
CONTACT SOCKET PLATING:
BLANK - SILVER
AU - GOLD
FLEX RELIEF STYLE:
BLANK - FLEX RELIEF I.D. 0.135 [3.4mm]
RECOMMENDED CABLE O.D. 0.100 - 0.220 [2.5mm - 5.6mm]
L - FLEX RELIEF I.D. 0.225 [5.7mm]
RECOMMENDED CABLE O.D. 0.220 - 0.285 [5.6mm - 7.2mm]
SEE TABLE FOR
FLEX RELIEF SIZE
1.99
50.6
0.87
22.0
F
CUSTOMER DRAWING
NOTES:
1. CONNECTORS AND HANDLES ARE SHIPPED SIDE BY SIDE OR IN BULK.
G
27473
03/27/15
PC
TJK
2. MATERIALS:
HANDLE METAL - ZINC ALLOY, NICKEL PLATED OR BLACK OR WHITE PAINTED
F HANDLE PLASTIC - THERMOPLASTIC, BLACK
CABLE CLAMP - THERMOPLASTIC, BLACK
FLEX RELIEF - THERMOPLASTIC, BLACK OR WHITE
HOUSING AND LATCH - ZINC ALLOY, NICKEL OR BLACK SATIN CHROME PLATED
INSULATOR - THERMOPLASTIC, GREEN OR BLACK
GROUND TERMINAL - SPECIAL COPPER ALLOY, TIN PLATED
CONTACT SOCKETS - SPECIAL COPPER ALLOY, SILVER OR GOLD PLATED
O-RING - THERMOPLASTIC RUBBER, BLACK
F
27081
01/25/13
BL
TJK
3. THESE PRODUCTS ARE RoHS COMPLIANT.
E
25891
9-9-08
SRC
TJK
D
25711
10-17-07
JGK
TJK
UNLESS OTHERWISE SPECIFIED
1. ALL DIMENSIONS IN INCHES
- TWO PLACE DECIMALS
0.01
- THREE PLACE DECIMALS
0.005
- ANGLES
1
- ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R.
C
24940
3-11-05
JL
TJK
B
24552
10-13-03
JL
BRH
2. FEATURES ON THE SAME CENTERLINE
MUST BE ALIGNED WITHIN 0.002
A
24446
8-12-03
JL
BRH
3. REMOVE ALL BURRS
REV
ECO NUMBER
DATE
REVISIONS
BY
APVD
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
STAR SYMBOL DENOTES CRITICAL DIMENSION
DO NOT SCALE DRAWING
SolidWorks CAD File
SIZE
WIDTH
MULT
FINISH
03-07-03
NAME
BY
BRH
SPEC No.
SCALE
1.5:1
CHKD
BRH
8-12-03
APVD
BRH
8-12-03
FEMALE XLR CONNECTOR, RoHS
B
TEMPER
MATERIAL
SPEC No.
FIRST USED ON
DATE DRAWN
LBS/M
SHEET
PART No.
1
OF
AAA_FZ SERIES
1
REV
G
很抱歉,暂时无法提供与“AAA3FZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+53.46467
- 15+52.81901
- 50+52.14211
- 100+51.48604
