Low resistance chip resistors
(short-side terminal)
■RL series
Features
・ Innovative structure that takes consideration of heat dissipation suppress the surface
temperature enabling the small sizes reducing the influence of heat on surrounding
components.
Applications
・ PC power sources, inverters, automotive electronics, adopters, industrial machines
*1
RL series
Current sensing surface mount resistors
* 1:Except for RL0510, RL1632 and RL3264
◆Part numbering system
RL 1220 S - 1R0 - F
RL 1632 S - R047 - F - T5
Resistance
tolerance
Packing quantity
:T1
(1,000pcs)
T5
(5,000pcs)
Nominal resistance
Value 1R0=1.0Ω
Series
code
Resistance tolerance
Nominal resistance Value 4digit
Temperature coefficient of resistance
Series
code
Size : RL0510, RL0816, RL1220
◆Electrical Specification
Type
Power
ratings
Temperature
coefficient
of resistance
Resistance range(Ω) Resistance tolerance
(ppm/°C)
1/8W
RL0510
1/6W
1/4W
0 ∼ +350(T)
0 ∼ +200(S)
1/5W
1/4W
RL1220
RL1632
1/2W
57
ー
100m≦R≦6.8
10,000pcs
ー
-55℃
7.5≦R≦68
0 ∼ +200(S)
43m≦91m
0 ∼ +350(T)
10m≦91m
√(P・R)
E-24
~ 125℃
5,000pcs
100m≦R≦10
0 ∼ +200(S)
11≦R≦100
510m≦R≦4.7
0 ∼ +200(S)
0 ∼ +500(T)
*1
ー
100m≦R≦4.7
20m≦R<100m
0 ∼ +200(S)
0 ∼ +350(T)
Packaging
quantity
±5% (J)
50m≦R<100m
0 ∼ +350(T)
0 ∼ +100(R)
Resistance Operating
value series temperature
5.1≦R≦47
0 ∼ +100(R)
1/3W
±2% (G)
0 ∼ +200(S)
0 ∼ +100(R)
RL0816
±1% (F)
Maximum
voltage
*1
56m≦R≦470m
33m≦R≦51m
ー
ー
27m≦R≦30m
18m≦R≦24m
ー
10m≦R≦16m
RL series with resistance tolerance 0.5% is also available. Please contact our sales office.
ー
T1
T5
◆Dimensions
L
Size
Type
RL0510
W
RL0816
a
RL1220
t
(inch)
R≦0.2Ω
R>0.2Ω
R≦0.082Ω
R>0.091Ω
R≦0.068Ω
R>0.075Ω
RL1632
0402
L
W
a
1.00±0.05
0.50±0.05
0.15±0.10
b
t
0.25±0.10
0.35+0.15/−0.10
0.15±0.10
0.35±0.10
0.25±0.20
0.45+0.15/−0.10
0.20±0.15
0.45±0.10
0603
1.60±0.20
0.80±0.20
0.20±0.15
0805
2.00±0.20
1.25±0.20
0.40±0.20
0.40±0.20
1206
3.20±0.20
1.60±0.20
ー
1.00±0.15
0.50±0.20
0.40±0.10
0.50±0.15
b
(unit:mm)
100
50
−55
50
100
RL series
Ratio to rated power (%)
◆Derating Curve
125 155
Ambient temperature (℃)
◆Resistance to power pulse
Maximum pulse power limit(W)
200
RL7520W-R10
RL7520-R10
150
100
Test procedure
RL3264-R050
Voltage pulse is applied to the test samples mounted
on the test board.
RL1632-R050
After each pulse, resistance drift is measured. Pulse
50
voltage is increased until the drift exceeds +/-0.5%.
RL1220-R10
0.01
The power at that voltage is defined as the maximum
0.1
1
10
pulse power.
Pulse duration(seconds)
58
很抱歉,暂时无法提供与“RL1220T-R015-J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5000+0.359145000+0.04348
- 10000+0.3352110000+0.04058
- 25000+0.3184525000+0.03855
- 50000+0.3119850000+0.03777
- 125000+0.30528125000+0.03696
